Image Problem In IR8070
  • abkonnet
    • Mar 2008
    • 166
    Hi in IR8070 one portion of the copy images gets lighter. I have attach the photo of the image it taken from print from computer in drawer3 which is A4R. I have took Copies by fully opening the Copy board door The copy produce is fully black with out any white spots.Also i does not notice any problem in second side of the two side print. cleaned the Transfer Charging wires.I think It may problem with Transfer Charging Mechanism or Transfer Guide. But i dont know what cause the problem.
  • SCREWTAPE
    • Jul 2025
    You just answered yourself.
    • abkonnet
      • Mar 2008
      • 166
      What Exactly cause the problem. I cleaned the Transfer Charging Mechanism and Transfer Guide But still i have the problem.
      • SCREWTAPE
        • Jul 2025
        Replace it.
        The charging wire can't hold bias charge that appied to it.
        I would also change the primary and pre transfer corona.
        • 20YRSEXP
          • Oct 2008
          • 281
          It looks like the transfer/separation assembly. Is that on the lead edge? It looks like it is lifting slightly or the corner is hitting the separation assembly. Is the nylon string still on it? The reason you won't see it with a totally black page is because the extra toner on the page can actually weigh the paper down enough that it won't lift the same way. When the copy lifts off the transport bed it will not pull the toner off the drum properly. It has been the cause more often than not.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • abkonnet
            • Mar 2008
            • 166
            It happen in the Lead edge of the Paper and not on the second side of the copying while taking two side print. It always happen. It only happen on A4R and when taken in A4 from the first drawer the density is slightly lower in the area. What is nylon string?
            • 20YRSEXP
              • Oct 2008
              • 281
              The nylon string is that clear plastic string that crosses over the separation/transfer assembly. If it is missing soometimes the paper will catch on the corona assembly. On the second side the paper has been charged and pressed and changes the properties of the paper, sometimes the second side is worse sometimes it can be better. Did you change all the corona wires?
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                I don't mean to oversimplify, but it looks like plain old humidity in the paper. If you rotate it 180 degrees and the light spot moves 180 as well, its the paper. Also, the fact that it doesn't do it on the second side sorta points to paper as well.
                • 20YRSEXP
                  • Oct 2008
                  • 281
                  Moisture in the paper crossed my mind too, but the light area is very specific. Normally damp paper will have a more overall effect. But anything is possible and I wouldn't rule it out. Try a fresh ream.
                  • abkonnet
                    • Mar 2008
                    • 166
                    I think Moisture is doesn't problem i first checked it out with fresh paper. Can u Pls put the picture of the Nylon string where it exactly found. I confused over it. What corona Points to Transfer charging wires or Separation Charging wires. I get error 68 or 69(Exactly dont know which error i checked it out and tell) three days before i cleaned Transfer/separation unit and i end up with this problem. I always face a big trouble to overcome when some thing wrong to this Machine, IR8070 is a complicated machine for me.
                    • 20YRSEXP
                      • Oct 2008
                      • 281
                      How old is your machine? How many copies are on the Transfer corona assembly? If you have a new transfer/separation corona assembly in your hand and look down at it you will see the corona wire inside. Above that you have a black plastic guide and on top of that you have very thin clear "strings" that go across the opening. If you have replaced wires before you need to remove it to get the wires in. If you haven't replaced wires before then we need to start there. Have you done basic maintenance on this machine?
                      • andy21557
                        Help Desk Technician
                        • Jul 2009
                        • 62
                        image issue
                        thoroughly clean the t/s assy and replace the wires .. just cleaning them helps a little but not much ... but i actually think your problem is the lower fuser bearings ... metallic rust/dust migrates into the t/s assy while doing duplex copies this can also explain the e069
                        • abkonnet
                          • Mar 2008
                          • 166
                          Machine runs 10,00,000 copies.
                          • abkonnet
                            • Mar 2008
                            • 166
                            There was no problem with Nylon string. It was present.
                            • Herrmann
                              • Jan 2006
                              • 792
                              Take the trans/sep assy, lower the sep wires by one 360 dregree turn each on the screws at the backside and raise the trans wire by one turn also, this should help.
                              Btw: this works on all bigger canon like the 7085, ir 105 and vice versa.
                              give it a try
                              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
