Hello, I have a 5000 that when the customer uses the rdf the rear of the copies have light streaks thru the page. Of the glass, copies r fine, just when rdf is used. From the samples I have seen it seems like its just the back side but can't confirm yet. Any suggestions would be super.
IR 5000 Light copies when RDF is used
ensure the slit glass is free of debris and the height of the feeder is correct
Copier>Option>User>SPECK-DP to "1" will notify the user to clean the glass when dust is detected on the slit glass.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
why would u replace the reader controller for a light image rear side/seems like a waste of time !!!!!!**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
