I have an other weird problem (The other one is the fuser not getting hot fast enough in an other thread here)
The copier have the ADF, if I copy a single sheet, no problem, I can repeat it multiple time.
But as soon as I put 2 sheets or more in the adf it crash (black LCD screen) and eventually the error led come on.
It do it every single time, when it happen the 2 sheets are on the glass and the scan was completed, the print was starting, the sheet was moving, then everything stop, right before the sheet get to the transfert belt.
I have read that maybe it's a faulty fuse PCB?
Thanks for your help
