6551 E001
  • tjveno
    • Aug 2025
    6551 E001
    I have a 6551 with an E001 code thermistors and thermostats test ok. Any tips. Also any info on clearing this code for testing. Manuals on order.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Open front door and look below the control panel for a little hole. Use a paperclip to press the button in there to get into service mode. Go to *4* function, clear, err and press ok. This will reset the code.
    Other things to check are the thermal fuse and lamps for continuity. It was rare but the connector in the back caused some intermittent codes. Most of the time I'd just reset the code and if it came back later replace the thermistor.
    • 20YRSEXP
      • Oct 2008
      • 281
      I pretty much agree with DLP. After resetting the machine start it up with the door open and the switch actuated. Watch the lamps and see if they light up. If they do they have continuity and power. Just be sure they both light up, sometimes only one lights and it looks like both. Those rear connectors sometimes need to be shimmed out for better contact. I would also do a visual exam on the contacts inside the rear connectors (both frame and fuser side) and make sure the copper tabs are not broken. Otherwise, resetting and seeing if it runs is always an easy step. If it starts up and doesn't code out you should be good to go. If it comes back in a day or so replace the thermistors as DLP said.
      Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • 23009
        Along the same lines as 20yrs, I have seen oil vapor from the web cause arcing at the contacts of the modular connectors. If you have caught it early you may be able to flush out the connectors with electrokleen. If you detect any burned contacts or melting of the connector you'll have to replace both halves of the connector. =^..^=
