Canon ir 105 jam code 0218
  • xcopytech
    • Aug 2006
    • 1783
    Paper stop beforere registration roller.
    Jam code 0218.
    Registration roller do not rotate.
    Replaced registration and registration brake clutch but still same.
    Main motor M1 work good.
  • teckat
    • 16083
    Jam code 0218.
    old pub
    The spring (FS5-2978-000) on the main drive had slipped over the coupling (FB6-0581-000) causing no drive to the registration rollers. Repositioning the spring resolved the jamming problem.
    other pub> when copying only-
    When copying from the original glass or document feeder, the copy paper will feed to the registration roller and stop. The machine will continue to rotate but the paper will not feed. The unit will have to be shut down to reset the malfunction. This issue only occurs when copying.
    Solution :
    Check for a loose connection at the DDI-S interface cable. This cable connects the main controller cage to the reader controller.
    • D_L_P
      Self Employed
      • Oct 2009
      • 1196
      One other thing to look at is the inlet guide. It gets deformed and the guides pinch together so that there isn't enough clearance for a sheet of paper.
      But is sounds more likely to be what teckat posted
      • SCREWTAPE
        East Coast Imaging
        • 3396
        This code is for PS60 image write start sensor. Jam code 0218 can be caused by CL5 and the registration clutch. Check PS60 flag for cuts and also putting a extra wrap on the sensor flag can resolve the jam code.
        • teckat
          • 16083
          Pic of CL5
          IN MULTI FEED DRIVE ASSEMBLY
          FH6-5016-020= CL5
          • xcopytech
            • Aug 2006
            • 1783
            Thanks to all, problem was spring on main drive.
            Now have second problem.
            When copy or print A3 everything is ok, but when copy or print A4, machine print 30-40 pages ok and then jam with half image on paper.
            It is look like registration problem, but registration and registration brake clutches are new.
            • teckat
              • 16083
              post jam code
              • xcopytech
                • Aug 2006
                • 1783
                jam code is 010A
                • teckat
                  • 16083
                  jam code is 010A
                  Are u Duplexing ??
                  delay pick up for A4 paper location
                  • xcopytech
                    • Aug 2006
                    • 1783
                    No duplexing.
                    Simplex print or copy. Paper stop on transport belts.
                    When jam, on print no lead edge margine and have about half image on paper.
                    A3 print or copy OK.
                    • teckat
                      • 16083
                      No duplexing.
                      did u check that A4 Tray set up
                      • xcopytech
                        • Aug 2006
                        • 1783
                        Yes.
                        • teckat
                          • 16083
                          what happens when u swap trays and or paper location ??
                          if registration issue still follows the procedure above, it has to be in the software / or something set up in service mode levels
                          • moein9802
                            • Jan 2021
                            • 1
                            Re: Canon ir 105 jam code 0218
                            please help meeeeeeeeeeeeeee
                            i have a 0218 jam code canon 7095-7105
                            my everything is ok but again my car has a jam code 0218
