Canon imagePASS-C2 can't communicate with ir C3220 copier
  • scayer
    • 18
    Our Canon imagePASS-C2 now can't communicate with its' ir C3220 copier/printer.
    We can communicate through the network with the imagePASS-C2 controller, using Fiery's Command WorkStation 5.
    We can, for example, clear the spooled print files on the controller's disk, but cannot reach the copier/printer from that utility.
    The copier/printer cannot either establish a connection with the imagePASS-C2 controller.
    We have played around with the 2 cables (both the cross-over etherNet cable, which we even changed, and the SCSI communication cable, of which we switched both ends), but to no avail.
    We previously had a similar but intermittent problem which had been resolved by playing around with these cables, over a few days.
    I have been suspecting a flaky etherNet connector on either end, but don't know how to validate this as the real source of the problem.
    Maybe it is the SCSI cable or connectors ?
    It is quite troublesome to lose access to this printer, as it is an important outlet for our architectural work.
    Any ideas or suggestions would be quite welcome.
    Serge
  • teckat
    • 16083
    Serge
    Is the Printer Tab (for the imagePASS) shown on the Copier's LCD Screen ???
    IMG-CONT - in Service Mode - the Setting MUST BE set to 3
    make sure C2 dip switches are not set to download mode
    Verify that the imagePASS and the copier are connected via a crossover cable (not a straight through cable or a rollover cable). Test the cable to verify it is good (can connect two computers together with it and have each one try to ping the other's ip address).
    Try re-seating the boards and connections on/between the 2 devices. Pay special attention tothe NIC in the copier and the internal NIC in the imagePASS (the imagePASS internal daughter NICis called the'Video Board').
    Give your laptop an ip address of 10.255.255.1 with a subnet mask of 255.255.255.0. Disconnect the crossover cable from the imagePASS and connect it to your laptop's network interface. Your laptop will now be connected to the copier via the crossover cable. Try to ping the copier's ip address (10.255.255.2). If you get successful replies, the problem is most likely on the imagePASS side. If the copier fails to reply, the problem is most likely on the copier side.
    Give your laptop an ip address of 10.255.255.2 with a subnet mask of 255.255.255.0. Disconnect the crossover cable from the copier and connect it to your laptop's network interface. Your laptop will now be connected to the imagePASS via the crossover cable. Try to ping the imagePASS' ip address (10.255.255.1). If you get successful replies, the problem is most likely on the copier side. If the imagePASS fails to reply, the problem is most likely on the imagePASS side.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      If it worked before?
      I would try another crossover cable for now.
      There are more reasons that can cause this.
      • scayer
        • 18
        Teckat,
        Thank you for your quick and obviously cogent response. Here are my answers to your questions and suggestions :
        Is the Printer Tab (for the imagePASS) shown on the Copier's LCD Screen ?IMG-CONT - in Service Mode - the Setting MUST BE set to 3
        Yes, it is set to 3.
        Make sure C2 dip switches are not set to download mode
        No, they are both DOWN.
        Verify that the imagePASS and the copier are connected via a good crossover cable
        Yes, it works fine.
        Re-seating the boards and connections on/between the 2 devices.
        No, the cross-over cable and its RJ-45 connectors work fine.
        No, I haven’t checked the video link cable,nor its connectors.
        Yes, it works fine; I can even access the copier’s Remote User Interface with my browser.
        Yes, it works fine; I can even access the controller’s Webtools interface with my browser.
        I just have to find a way of testing the video cable, which appears SCSI-like but with only 40 connectors, and its connectors. Do you know if this FH2-7042 cable is easily available ?
        Also, I noticed that on the C2-side that it shows the Gateway Address as being 255.255.255.255, it seems to me it should show our router’s gateway address of 192.168.1.1. Is this normal ?
        Even though I can access the C2’s Webtools interface, I can’t use the Javascript Configuration Scripts : these load but do not provide any supplementary configuration screens (maybe because i’m running Java 1.6.0 r20 instead of 1.4.2 ?).
        • scayer
          • 18
          ScrewTape,
          Thanks for your suggestion.
          The crossover cable is new and it works fine, as stated in my response to Teckat's suggestions.
          You mention other reasons that can cause this; do you have any other suggestions ?
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Memory dimms (Ram) from your Imagepass.
            • teckat
              • 16083
              ScrewTape,
              Have u tried to remove and re seat the NETWORK BOARD on 3220 ??
              does the imagePass C2 side LED display read 00 ??
              00=ok should be working !!
              FF=Check internal & external cables & connections
              E3= DIMM issue/ re seat DIMM in C2 DDR DIM2
              During a normal boot sequence, the two digit segment may read: 16, 64, 29, 8A, during the 8A the machine is finalizing the splash screen (scroll bar on the copier). When this is done the segment display will go 00, FF, then 00.
              If it goes to 00 an still says please wait, it is possible that the system software is corrupt.
              re-install the system software for C2 fiery
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                I don't know how much this matters, but the imagePASS-C2 does not support CWS 5.
                Is it possible that it worked OK before upgrading to version 5?
                I'm just wondering if CWS 5 somehow corrupted the system software on the RIP.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  I had a case where the imagepass was stuck at "please wait".
                  Popped in a different memory stick and it just started printing.
                  • teckat
                    • 16083
                    Good Point_SCREWTAPE / I Forgot, have also done that fix ****
                    • teckat
                      • 16083
                      Canon imageRUNNER C3220== Color Network Printer Unit-C2
                      Canon imageRUNNER C3220== imagePASS-C2
                      Canon imageRUNNER C3220== PS Print Server Unit-C2
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        Sorry, my bad.
                        I was thinking that the imagePASS C2 had System 5 or older on it.
                        Must be because I've seen very few C2s, almost all C1s.
                        Turns out it runs 7e, so it's compatible.
                        Good catch!
                        • scayer
                          • 18
                          THAT WAS IT !
                          A few months ago we had added a second 256MB DIMM; since we had just gotten the machine, we didn't know this was why it would flake out intermittently.
                          As soon as I removed that second DIMM and rebooted, the copier/printer immediately recognized the controller !
                          You guys are top-notch.
                          THANK YOU !
                          Serge
                          • teckat
                            • 16083
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              THAT WAS IT !
                              THANK YOU !
                              Serge
                              Anytime.
                              Glad to hear your up.
