NP6016 E007
  • goldencup
    • Nov 2008
    • 366
    [Error Code] NP6016 E007
    Hi! i would like to seek help from you guys on how to solve E007 of Canon NP6016. I know its somewhere in the fixing unit but i don't know where to start . Is there a way to reset it? One thing i've notice on the fixing unit is that the gear on the rear side (..the .white gear which look like a pie )the one that is lift by a small motor is already lifted too high! I used to see the arrow on the gear is pointed somewhere in the middle but now it's already pointed at the highest adjustment, what seems to be the problem? By the way the film is still ok ...and im still trying to prevent it from ripping . Hope you can help me. Thank you very much!!!
  • Brian8506
    • 1664
    The film has shifted toward the front and is not being read by the film sensor. You can try to physically move it further to the rear but one thing I found with that machine years ago is it had to be level or the film would shift. Alternative is to replace the unit. Those fixing units aren't fun to disassemble
      • 22997
      There is a very detailed description in the manual of the procedure to center the fixing film. It's ~ 5 pages and I'm not going to attempt to quote it off the top of my head after 12+ years. Look in the manual. =^..^=
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        That is one old machine.......might be a good opportunity for you to recommend replacement rather than repair. If you are going to attempt this---send me a email at blazebusiness@cox.net and Ill send you the information you need to remove and disassemble the fuser.
        • developer dumper
          • Oct 2008
          • 21
          best way to repair NP6016. Find the nearest dumpster and put copier in it.
          • teckat
            • 16083
            • teckat
              • 16083
              double click on poor pic below
