Ir 400 leading edge of the paper folds
  • abkonnet
    • Mar 2008
    • 166
    In IR 400 the corner of the leading edge of the paper folds. the paper folds after the Fixing rollers i cannot figure out what make this? I have attach the photo of the out put paper.
  • teckat
    • 16081
    Burrs on the Lower left door= red arrow/or incorrect pressure to idlers on the door may cause this effect.
    • SCREWTAPE
      East Coast Imaging
      • 3371
      Troubleshoot this. This is a simple machine. Run a couple of copies, jam the machine. This machine always had somewhat issues with its delivery area. Something gots to be deformed. This is a simple machine, don't let it beat you up. Step away and come back to it.
      Good luck.
      • abkonnet
        • Mar 2008
        • 166
        The paper is fold in the delivery area.
        • CanonHPTech
          • Apr 2007
          • 234
          Are you sure the fold is happening in the Left Hand Door/Delivery Area? The Separation Claws at the exit of Fixing Assembly do get dirty/damaged can cause this and also Lower Fixing Roller is notorious for dog earing pages. Back to the door area, I have had a couple where I ended up replacing the whole Door as an assembly for jamming. Eventually that door gets so warped it doesn't even line up with the paper path anymore. However, its not something you can see. Check the rubber delivery roller that is visible while the left door is closed from the outside that there are no tires on the shaft that are melted or torn off shaft. Good luck. Post results.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
          • teckat
            • 16081
            Change the door , like I posted/
            it is warped
            • dhanesh
              • Jun 2010
              • 63
              check exit cover and exit rollers and clean that unit
              DHANESH
              • teckat
                • 16081
                abkonnet is M.I.A
                no response in 3 weeks
