lemme guess something easy like rcon clear, ccd adj, wtlvl adj or stnd-pos??
Ir4570 copies upside comes very lighly????
You just took the time to post a reply "Hmmm ...What is that." Why didn't you post what repaired the machine instead?sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Agreed. Without a response as to what fixed the trouble....I know I won't feel very motivated to respond to future posts by him. Maybe it was something so simple he is ashamed to post the fix.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
beejong
beejong
You are a joker, wasting time.
How come YOU and BEEJONG have the same post, with the same problem, with the same bad spelling and grammar,changed the same 4 parts, and you live in two different countries.
http://www.copytechnet.com/forums/ca...ry-lighly.htmlComment
we is twins/ pulled apart/ & sent on our merry way**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
LindaOwen
He means the LEADING EDGE is light only for copies not for print and scan.
Try cleaning the TRANSFER CHARGING ROLLER and the DEVELOPING CLUTCH.Comment
