Ir4570 copies upside comes very lighly????
  • SESHU
    • 163
    #91
    Originally posted by teckat
    [ATTACH=CONFIG]9880[/ATTACH]
    we is twins/ pulled apart/ & sent on our merry way
    what' that meaning?????
    • Borsody75
      • Mar 2011
      • 83
      #92
      First the solution, then the meaning....
      • V-P
        • Apr 2011
        • 679
        #93
        What he means is:
        Dig first
        money later
        • spectraindo
          • May 2008
          • 313
          #94
          [IMG]file:///C:/DOCUME%7E1/Intel/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]The TRANSFER CHARGING ROLLER is the black sponge roller on the RIGHT DOOR of the machine, check if it is spoiled and clean only with a dry cloth.
          Transfer iR4570.jpgThe Developing clutch is CL3 on the MAIN DRIVE UNIT.
          • teckat
            • 16083
            #95
            Meaning is/
            How is it possible that two exact posts on the same subject/with the exact words and sentences, be posted by two different posters > in two different listed countries
            SESHU >10-13-2010
            KAKINADA, INDIA
            beejong > 5-14-2011
            sabah
            • SESHU
              • 163
              #96
              Meaning is/
              that's y iam saying???
              i am from my country. this is the one and only my topic.
              there is no matter. same complaint face another man another country.
              so those are not one. those are different.....
              any way i can solve the complaint 50 %.....
              • SESHU
                • 163
                #97
                [ATTACH=CONFIG]9884[/ATTACH]The Developing clutch is CL3 on the MAIN DRIVE UNIT.
                i also do it ..this method... but no improve....
                i face the problem first of it....
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5015
                  #98
                  • SESHU
                    • 163
                    #99
                    you before already tested???? zoraldinho
                    • teckat
                      • 16083
                      #100
                      [ATTACH=CONFIG]9895[/ATTACH]
                      color lines describe locations/& areas of cq issues-
                      make a copy/ keep in tool bag
                      • SESHU
                        • 163
                        #101
                        Re: Ir4570 copies upside comes very lighly????
                        thank you for replys...
                        finally i recently main scan unit replaced...
                        and changed various drums and toners also...
                        copier problem is same....
                        and
                        devolping assembly in right side door black sponze roller also replaced to another mechine its works fine....
                        so????
                        • mr.daus
                          • Apr 2011
                          • 98
                          #102
                          Hi..
                          One ir4570 recently i have to make copies it will comes upside very lightly..
                          I have to change some parts for better results.
                          That parts are..
                          1.new drum and charging roller
                          2.cd-rot unit toner fully cleaned with blower changed with new toner.
                          3.new fuser film .
                          4.laser dust glass clean with smooth cotton.
                          But no result..???
                          I can make prints and scan it will comes very clearly..
                          But only copies are very lightly on upside only..
                          How to make changes for beeter result for as it is copy...??
                          I can upload images for checking variation difference.
                          [ATTACH=CONFIG]6588[/ATTACH] [ATTACH=CONFIG]6589[/ATTACH] [ATTACH=CONFIG]6590[/ATTACH]
                          IMAGES ARE ..
                          1.copy
                          2.computer to print
                          3.scan to computer
                          what to do for better result..
                          try to check more thoroughly first with the roll pressure, as well as in parts of its bearings.
                          it sometimes happens because the roll-suppressing its poor condition, resulting inbleeding at the time of heating at the side edge
                          firdaus +(62)8195002007 firdaustrish@ymail.com
                          • Simons
                            • Jun 2008
                            • 490
                            #103
                            Has the hinge been adjusted or replaced?
                            • SESHU
                              • 163
                              #104
                              thank u for reply.
                              i can also pressure roller adjusted wherever copy light is ....
                              and new film replaced also... result is same ....
                              i think this problem appears only copy and print...
                              when make scan to computer it will fine ....no big difference is there whenever do this..
                              so what's next????
                              • SESHU
                                • 163
                                #105
                                hinge?????
                                where it is????
