Ir4570 copies upside comes very lighly????
  • badboys
    • Oct 2010
    • 69
    #31
    Hmm.....like i said this is one weird problem you got.
    If the CIS is faulty, it will also affect the scan to pc.
    If the Laser is faulty, it will also affect the print from pc.
    And you had even replace the drum, developer & fixing assy earlier...
    Oh GOD please help Mr SESHU...shine him with some lights.
    • SESHU
      • 163
      #32
      scan to pc it will be all over sides full of quality..
      i show you 3 image ..scan-to pc.
      so now scanner problem or laser assy or what???
      • SESHU
        • 163
        #33
        iam using glass and feeder also..
        those are same print with same problem.
        upside lightly???
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          #34
          Enter Service Mode
          Copier>Function>CCD>CCD-ADJ, be sure to press OK in lower right corner.
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1257
            #35
            Originally posted by teckat
            4570
            CCD array collects the reflected light coming through the rod lens
            array.
            The machine's CCD sensor is a 1-line linear image sensor consisting of 7488 photocells. After completion of
            photoelectric conversion in the light-receiving block, the signals are output to the AP circuit in the reader controller
            circuit board in parallel for each channel (total eight channels) of the CCD array.
            [ATTACH=CONFIG]6634[/ATTACH]
            The contact image sensor (CIS) is used to control analog image processing in the following flow of work:
            The light reflected by the original is collected by the rod lens array;
            the light is then collected by the CCD array;
            the light is converted into an electric signal by the CCD array (photo-conversion) for output.
            The CCD array consists of a total of 8 channels (units). Each channel possesses its own output correction table used
            to process an input intensity signal for gain correction for output of an image signal
            [ATTACH=CONFIG]6633[/ATTACH]
            Thanks Teckat - now I understand. Good info-shooting you some rep power for your efforts!
            Seshu, Have you even tried the ccd adjust that Mrfixit proposed? He gave you that advice twice now. Give it a try.
            • badboys
              • Oct 2010
              • 69
              #36
              After analyzing/considering your issue here, it is possible that the problem probably lies with the "Image Processing Module" which actually took place in the Main Controller PCB. Refer to service manual "Chapter 4.5.1 Overview of Image Flow". Observe the different of Image Data flow for Copy Function, Scan Function & Print/PDL Function. Go through it & you'll understand what I mean.....Enjoy Your Read
              • teckat
                • 16083
                #37
                upside lightly???
                The process of a SCANNED Image off the Glass back to a PC = then Printed from PC to 4570 is different then that of a Copy that is Scanned of Glass and Printed directly on 4570
                • SESHU
                  • 163
                  #38
                  now what to do??
                  how can i adjust ccd value..
                  • SESHU
                    • 163
                    #39
                    Originally posted by mrfixit51
                    Enter Service Mode
                    in Copier>Function>CCD>CCD-ADJ mode> which value can i increase or decrease for that problem solved.
                    when i press Copier>Function>CCD>CCD-ADJ > PRESS O.K ..
                    it will be displayed service >active>o.k message will be displayes.
                    after then i can check making copy again..
                    it will comes as it same upper lightly.. no better result found????
                    WHAT TO DO MRFIXIT..
                    HOW TO INCREASE COPY DARK IMAGE IN UPPER SIDE???
                    • teckat
                      • 16083
                      #40
                      Carefully remove the copy glass / turn it over & clean/ turn it back over & clean - I used to place white paper all over glass> close down DF then do a CCD ADJUST
                      There is no adjustment for a Copy image issue that effects one side or area
                      • SESHU
                        • 163
                        #41
                        carefully remove the copy glass / turn it over & clean/ turn it back over & clean - i used to place white paper all over glass> close down df then do a ccd adjust
                        there is no adjustment for a copy image issue that effects one side or area
                        so..
                        How can i print test print
                        i got some one idea.
                        make a test print what is diffrence between copy and test print.
                        Service mode>type>which one is test print????
                        • SESHU
                          • 163
                          #42
                          So what's the problem???
                          How can i adjust the image all sides full of quality..
                          SOLUTION IS THERE/NO??????
                          Teckat what to do???
                          • teckat
                            • 16083
                            #43
                            so..
                            Test prints are not the issue here/ forget about them for now/
                            test prints are internal prints to check on issues not related to your so called COPY off the Glass Issue
                            did u do the cleaning glass procedure ??
                            • SESHU
                              • 163
                              #44
                              yes ..i do clean glass precedure and ccd adjust also...'
                              no improvement /better result in the image..
                              please give me solution..
                              • teckat
                                • 16083
                                #45
                                [no improvement /better result.. ????]
                                what do u mean by that statement
