Canon IR C6800CN, prints evenly closely spaced black stripes in the direction the paper exits the printer (1mm black/white stripes horizontal to long side of A4 paper / stripes vertical to short side of A4 paper). The prints are the same whether there is a paper on the copier glass or there isn't a paper placed on the glass, same applies when trying to print using the network connection. The following errors E000747-2028 , E000747-0331, E000020-0190 are generated intermittently and the main power needs to be cycled. I have performed a drum phase adjustment in service mode as it was requesting "Check Drum Phase", prior to adjusting drum phase copies were blurred with black/white stripes, now copies have only black stripes. When performing test print MCYBk Horizontal Stripes (TYPE=10) using service mode in colour, print outs have Red, Blue, Yellow, Black (12mm stripes horizontal to long side of A4 paper / stripes vertical to short side of A4 paper) and grainy with all colours having a tint of black. When test print - 16-Gradation (TYPE=4) image is overlapped with black stripes. The pressure roller seems to be wearing out as I found a lot of red silicon shavings which I cleaned, the shaving seem to be from one end of the lower pressure roller and the unit housing the fuser gets very hot, compared to when it was in the UK. Currently looking to source new pressure roller and fixing roller. The machine is currently in Sri Lanka, not sure if there needs to be temperature adjustments (humidity switch, etc). The A-Si drum has completed just over 250000 copies and the service manual states it has a life of 500000. Please advise if there is more to it than replacing fuser parts which I am looking to source. Please advise where the problem could be. Local Canon dealer in Sri Lanka is not interested, as they didn't sell the machine. I have no problem taking it apart as I have cleaned the primary charging wires in the past.
IR C6800CN Black stripes: E000747-2028 , E000747-0331, E000020-0190
[Error Code] IR C6800CN Black stripes: E000747-2028 , E000747-0331, E000020-0190
Last edited by manya; 01-17-2011, 01:19 AM.Tags: 250, 500, 5000, canon, clo, cloth, cycled, fuser, glass, horizontal stripes, hot, image, life, pressure roller, purchase, saddle stitcher, sdl, service manual, unit -
Thank you will try what you suggestedComment
Make sure your Firmware is at v16.03a- it addresses some xtra E747 issues
Board cleaning/ and positions check for E747 Issues
Clean the terminals (both front and back) of the Sub PCB using a lint-free cloth, lightly impregnated with alcohol. Be sure not to damage any of the terminals. If damage occurs, replace the Sub PCB in Question.
After the alcohol has dried completely, hold the Sub PCB firmly and slowly insert it approximately halfway.
You can see this by looking at the mounting holes of the PCB. The mounting holes will be to the
left of the cage frame.
After the PCB is mounted half-way, place the mounting screws loosely in place (approximately 1mm between screw and frame).
Measure between Sub PCB’s. As each PCI slot is lined up, the measurement from one Sub PCB to the next should be equal.
When measuring, do not use the upper PCB of the PDRM-EF-A PCB assembly.
Measure the lower PCB as it is connected to the PCI slot.
If all Sub PCB’s are equally distanced, press the Sub PCB into a full mounted position, and then tighten the screw nearest you first.
Then tighten the screw nearest the frame second.
Re-measure and confirm the distance from one Sub PCB to the next.
Once confirmed, re-assemble the Main Controller Cage Assembly Cover and Rear Cover.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Teckat, thank you for the brilliant description, will do this. How can I check the firmware and update it if necessary to v16.03a. I understand I will need a Canon Service Support Tool to perform a firmware update, which I don't have. Do you know where I can purchase the firmware and update tool or where I can download it from?Comment
COPIER>DISPLAY>VERSION
MN-CONT= will have your version
Use it to indicate the ROM version of various PCBs (copier, accessories).
- The format of display is as follows: if R-CON XX.YY>, XX: version; YY: R&D control number.
- If no PCB is installed, the display will be as follows: <-:->.
DC-CON= Use it to indicate the ROM version of the DC controller PCB.
R-CON= Use it to indicate the ROM version of the reader controller PCB.
PANEL= Use it to check the ROM version of the control panel controller PCB.
ECO =Use it to indicate the ROM version of the ECO PCB.
FEEDER =Use it to indicate the ROM version of the DADF controller PCB.
SORTER =Use it to indicate the ROM version of the finisher controller PCB.
FAX= Use it to indicate the ROM version of the FAX board.
NIB =Use it to indicate the Rom version of the network interface PCB
PS/PCL =Use it to check the Version of Printer board (PS/PCL function)
LIPS= Use it to check the version of the UFR board (LIPS).
SDL-STCH =Use it to check the ROM version of the saddle stitcher controller PCB.
OP-CONT= Use it to indicate the ROM version of the option controller PCB.
BOOT ROM=Use it to indicate the boot ROM version of the main controller PCB.
- if copier model/GDI-UFR model, xx.yyC
- if LIPS model, xx.yyL
- if PS/PCL model, xx.yy.N
MN-CONT= Use it to check the ROM version of the main controller PCB.
DIAG-DVC= Use it to indicate the ROM version of the self diagnosis device.
RUI= Use it to indicate the version of the remote UI.
PUNCH =Use it to indicate the version of the punch unit.
LANG-EN= u will various Languages stored in your printer**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Re: IR C6800CN Black stripes: E000747-2028 , E000747-0331, E000020-0190
Thanks for all the advice, I have tried everything suggested but still the same problem as in the previously attached pictures.
Found red shavings in the fixing unit, from the lower pressure roller and upper fixing roller.
I think these need replacing. I think the machine is getting too hot and requires an air conditioned
room as it is located in Sri Lanka and there is quite high humidity, as the plastic vents on the left
of the machine has turned slightly brown since shipping it their from the United Kingdom.
The machine worked for about a month, since being shipped over.
If there is anyone in Sri Lanka who can fix this machine please contact me.Comment
yes your fuser needs rebuilding and yes this machine should be ran in a controlled environment. The heat and humidity will ruin the toner and starter while it is still in the developer units rendering the machine useless.
Your 747 error codes are a communication issue which could be a build up of corrosion, loose connector or possibly a bad board all together.
As for the digital lines you posted I would look at your replacing your RAM as teckat mentioned and replacing the Main Controller-Sub pcb FM2-5899-000Accidents don't just happen. They must be carelessly planned.Comment
u posted on this issue last January/February of 2011 ---???
where have u or this printer been since then ?
where I posted some issues for u to look at
did u replace the memory-
020-0190=YELLOW ISSUE///check patch image read sensor--check ITB Sheet
If the process unit is left alone for a long time in a high humidity environment, the primary transfer ATVC control mechanism that goes on when the main power is turned on can cause electrical discharge between the primary transfer roller and the primary transfer static eliminator. The discharge can cause the resistance of the primary transfer roller to fluctuate. Malfunction of the primary transfer ATVC control mechanism can lead to an error associated with E020 or can adversely affect color reproduction.
check in service mode below
COPIER>DISPLAY>MISC
ENV-TR Display the environmental ranges
Display the environmental ranges for transfer controlling according to the environment (temprature and humidity) inside the printer.
Range of value--------------
1: Low humidity (to 5.8 g)
2: Normal humidity (5.9 to 17.3 g)
3: High humidity (from 17.4 g)
Factory default value: The value adjusted at the factory/The value after RAM cleared: 2
COPIER>DISPLAY>ANALOG
TEMP-----Use it to check the machine inside temperature (environment sensor; in deg C).
HUM------Use it to check the machine inside humidity (environment sensor; in %RH).
ABS-HUM--Use it to check moisture content (environment sensor; in g).
PRINTER
Operating environment
(temperature range) 15 to 30 deg C
(humidity range) 25% to 80%
If the site is in a high humidity environment, turn on the environment
switch (so that the drum heater will go on regardless of the state of the main power switch.
(atmospheric pressure) 810.6 to 1013.3 hpa (0.8 to 1.0 atm)
there are numerous adjustments in service mode- in level 1/2 for high humidity environment
check your manual**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
