Canon IRC 5180 copying issues
  • r&s
    • 7
    Canon IC 5180 copying quality issues. Having issues only when using ADF or glass. Printing works fine. When copying I get a slight red background throughout the whole page. I also get lines that move around. This only happens when photo copying. Its got me baffled. Machine only has 45,000 page count.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    I'm very interesting.Let we see some scans.
    • philip1davies
      • Feb 2011
      • 23
      Magenta backround
      hello
      Have you tried auto gradiation ?
      This is a mode the user can re-calibrate the printer with the scanner
      Also
      How many colour copies has the Magenta drum done ?
      How old is the M drum ?
      The reason I ask these questions is the drum can do as little as 35k or as much as 80k it all depends on the age / number of copies / and the level of coverage. ( heavy graphics or toner coverage will reduce the life of the drum as much as 40%)
      I can instruct you how to obtain the drum info aswell as the auto gradiation if you want.
      Cheers
      Philip
      Canon engineer for over 30 years
      • charm5496
        • 2387
        clean your optics and adjust the CCD then run the auto gradation.
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          ...a slight red background...45,000 page count.
          Red as in Red, and not magenta right? It sounds as if there is a problem with the red channel in the CCD unit. I'd try replacing the CCD and turn it in for warranty since it has only 45k.
          Maybe a R-CON clear and re-entering the values for the CCD might work too.
          • charm5496
            • 2387
            i do not think the CCD would be covered under the manufacturer warranty cost would have to be greater than $300 or under 90 days from time of install.
