imagerunner 3570 Light Copies/prints on OP Side
  • mrfuser
    • 1622
    For some odd reason the pages coming out are lighter on the OP side than on the NON op side when exiting. New drum, fuser, transfer roller, cleaned it out and checked DV unit.
    Any ideas?
    Kelly
  • Gamut
    • Jul 2008
    • 216
    Did you clean mag roll in dev unit, had a few of those now, some cleaned, in others had to replace dev unit.
    • teckat
      • 16083
      Any ideas?
      Kelly
      Check for toner on the slit glass located on the scanner laser assembly/
      clean if needed
      Also check transfer roller is properly attached to the mounting bracket/
      check for binding in plastic bracket
      • WOETC
        Agree with previous posts, have also had deformed contact springs in the frame where they contact the transfer roller, gives same result.
