Canon iR3570 Fuser
  • iscott
    • Mar 2010
    • 344
    Canon iR3570 Fuser
    Pressure Roller is in good shape but the belt is torn. Can you buy just the belt and does anyone have the part number?
  • totoro
    • 568
    If you're referring to the fixing film then the only number I have is a Katun number which is 29129. That is just the film and the lube for it. I don't believe that Canon sells just the film by itself, you would have to order the whole fixing film ass. part # FM2-1793-020.
    Totoro
    • charm5496
      • 2387
      canon does not sell just the film and everyone who tries to save a couple of dollars by just buying the film usually ends up buying the entire film assembly because the film is pain in a$$ to replace and get it to work properly. Just my .02
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Charm and I are on the same page on this,, unless your labor is bone cheap, the savings of going with the film long term are eaten up by the extra service visits generated by using just an aftermarket film and grease. It is far more reliable to use the fixing film assembly that totoro mentioned...
        Add in my 2 cents worth and you now have .04!! ;-)
          • 22997
          I do quite well on rebuilt iR-3570 fusers. I don't know why you wouldn't rebuild them. Every one has worked and lasted the expected life. =^..^=
          • CanonSco
            Man About Town
            • Jul 2010
            • 368
            What's the cost difference on just the film as opposed to the fixing film assy?
            Yes, I am a nerd.
            Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
            • anothertech
              • 1760
              The 29129 film is about $30.00 us The assy is about $70.00 us dollars.
              We use a lot of the films, they work good, no problems.
              • WOETC
                I don't know the exact costs here in Oz. but the difference easily covers the labour, and the results with the Katun film are fine.
                • trevorgee
                  • Dec 2010
                  • 4
                  part number for fixing film is FM2-1812
                  • charm5496
                    • 2387
                    Must be a UK part number as that comes up no good in the parts system.
                    • WOETC
                      That's the 230/240v fuser. There are 3 different numbers.
                      • beatbrother
                        • Feb 2011
                        • 24
                        Re: Canon iR3570 Fuser
                        Make sure to put the right side of the film to be read by the rotating sensor (white/golden mark on edge of film)
                        Hint: do not remove the whole heating element just one side, and slide in and out the film thru that side
