canon ir5020i e602-003 no Harddisk
  • satitjangdee
    • Jun 2011
    • 49
    [Dead] canon ir5020i e602-003 no Harddisk
    The error code point to Harddisk fault but the machine no harddisk. How to solve.
    First, screen come up with the error code. I look for H/D but non, so I reseat 2 DIMM at the DC controller and main board.
    After that the screen never come on, green light is up.
    How to do guru?
  • copier tech
    • 8172
    Re: canon ir5020i e602-003 no Harddisk
    This model DOES have a HDD!
    It's located in the left scanner section of the machine (if i'm correct) top left area.
    Before replacing the hard drive try reloading the firmware.
    However if now you are getting nothing on the screen after you reseated the board etc I would suggest that you left a connection off!
    • satitjangdee
      • Jun 2011
      • 49
      Thank a lot! I will find it.
      • laitang
        • Nov 2012
        • 627
        Try replacing the hard disk drive and downloading the system software.
        • northernlife
          • Sep 2011
          • 847
          oh and they decided to glue the shit out of the ide cable. You will need an oem hdd to get this puppy going. I believe these are encrypted disks and you cannot do the .ini trick to get it to write to a non oem drive like the 2200's.
          • teckat
            • 16083
            How to do guru?
            try this before replacement/ a complete defrag of HDD
            E602-0003:
            While simultaneously holding down the 1 and 9 keys, turn on the copier's power so that the device will perform a hard disk write abort error recover session. Warning: This recovery process requires the checking of every sector of the entire HDD, and as such will take an extended period of time.
            a NG at end will mean u need a new HDD
            these OLD /REFURB HDD's can be used in iR5000/6000/5020/6020 SERIES if u don't have Canon OEM
            WM2-5222-000==HDS728040PLAT20 HITACHI
            SEARCH FOR THESE HDD”s ONLINE/
            HDWN 'FUJITSU MPC3032AT
            HDWN 'FUJITSU MPD3043AT
            HDWN 'FUJITSU MPE3064AT
            HDWN 'FUJITSU MPF3102AT
            HDWN 'FUJITSU MHK2060AT
            HDWN 'FUJITSU MPG3102AT E
            HDWN 'FUJITSU MHN2300AT
            HDWN 'FUJITSU MHT2020AT MF
            HDWN 'FUJITSU MHV2040AH
            HDWN 'QUANTUM FIREBALL CX6.4A
            HDWN 'QUANTUM FIREBALLlct10 05
            HDWN 'QUANTUM FIREBALLlct08 04
            HDWN 'QUANTUM FIREBALLlct15 07
            HDWN 'QUANTUM FIREBALLlct20 10
            HDWN 'TOSHIBA MK6014MAP
            HDWN 'TOSHIBA MK6015MAP
            HDWN 'TOSHIBA MK1016GAP
            HDWN 'TOSHIBA MK6017MAP
            HDWN 'TOSHIBA MK2023GAS
            HDWN 'TOSHIBA MK4032GAX
            HDWN 'IBM-DJSA-205
            HDWN 'IBM-DARA-206000
            HDWN 'IBM-DJSA-210
            HDWN 'ST34311A
            HDWN 'ST34313A
            HDWN 'ST310211A
            HDWN 'ST340015A
            HDWN 'ST92011A
            HDWN 'ST340014A
            HDWN 'ST940210A
            HDWN 'IC25N006ATDA04-0
            HDWN 'IC25N010ATDA04-0
            HDWN 'IC35L040AVER07-0
            HDWN 'IC35L020AVER07-0
            HDWN 'IC25N010ATCS04-0
            HDWN 'IC25N020ATMR04-0
            HDWN 'Maxtor 2B020H1
            HDWN 'MAXTOR 4K020H1
            HDWN 'Maxtor 2F030J0
            HDWN 'Maxtor 2F040L0
            HDWN 'WDC WD400BB-22HEA0
            HDWN 'WDC WD400BB-22JHC0
            HDWN 'WDC WD300AB-00BVA0
            HDWN 'WDC WD800BB-22JHC0
            HDWN 'HDS722540VLAT20
            HDWN 'HDS728040PLAT20
            HDWN 'SAMSUNG SV2001H
            HDWN 'SAMSUNG SV0211H
            HDWN 'SAMSUNG SV0221N
            HDWN 'SAMSUNG SV0411N
            HDWN 'SAMSUNG SP0411N
            HDWN 'ExcelStor Technology J120
            HDWN 'ExcelStor Technology J64
            HDWN 'Hitachi HTS541640J9AT00
            • satitjangdee
              • Jun 2011
              • 49
              Thank you to everyone for useful info.
              This site has many friendly friend.
