Horizontal Blank line - Drum issue?
  • Kendjr
    • Dec 2014
    • 8
    [CQ] Horizontal Blank line - Drum issue?
    This copier started to print blank/shaded lines recently. I have replaced the toner, but it has not helped. Can you diagnose if this is a bad drum, or another issue?BlankLine.jpg
  • kuby
    • Oct 2007
    • 1379
    Re: Horizontal Blank line - Drum issue?
    It would help to know the model number ????
    • Kendjr
      • Dec 2014
      • 8
      Sorry it is an IR 2270
        • 22937
        Horizontal? That means nothing to me.
        Is the line in the feed direction or crossfeed direction of the print?
        Is the line in the main scan or sub-scan direction of the original?
        • Kendjr
          • Dec 2014
          • 8
          it is a printer/scanner/copier
          The blank line is always in the front-back direction. The paper comes out with the long side, or the 11" side first.
          In other words, on prints/copies the line will be from left to right in portrait mode, (11" side to 11" side). There is one large shaded line, but also to other lines as you can see in the image attached.
          If we manually feed the printer, and have the paper fed with the short side (8.5") first, the line will appear from the top to the bottom of the paper, or from the 8.5" side to the other 8.5" side.
          If we scan papers, the line does not appear on the PDF electronically transmitted.
          Please let me know if you need any more information. Thanks and Happy New Year!
            • 22937
            Since the void does not appear in PDF scans, you have ruled out the scanner as the cause.
            The reason that the word horizontal is unclear, is because it's possible to feed the copy paper LTR or LTR-R direction. Additionally, I would have no way of knowing if the original image is laid out portrait or landscape. So there are four possible orientations. That is why it helps to use the proper terms feed/crossfeed for the copy paper, or main scan/sub-scan for the original feed.
            You've contradicted yourself, but of the three descriptions I'll go with the one that you've stated twice.
            Front-back indicates the crossfeed direction, or across the feed direction. And I think you are mistaken.
            Feed direction indicates a line in the direction that the copy paper feeds, and is consistent with the latter two descriptions.
            Voids in the feed direction are caused by three main problems:
            1) Exposure: A dirty laser slit glass will cause voids in the feed direction.
            2) Developing: An obstruction under the S-blade in the developing unit will cause voids in the feed direction.
            3) Transfer: A damaged transfer roller won't transfer toner in a band in the feed direction, leaving a void.
            • anothertech
              • 1756
              I like to go with Front to Back= front of copier to back of copier and
              Lead to trail= lead edge of paper coming out of machine to trail edge of paper
              It does sound like he means lead to trail, so the possible causes Blackcat listed are the places that should be checked.
              Dig into it a little bit and you should be able to see whats going on, unless your not a tech. If you are end user, you well probably need a tech to check it out.
              • allan
                RTFM!!
                • 5459
                Mybad did not focus. Yea mono component.
                Whatever
                • Kendjr
                  • Dec 2014
                  • 8
                  Thanks to everyone, it's greatly appreciated.
                  It is lead to trail. I am not a tech, and I was hoping it was something simple, which it does not sound like like it is.
                  I will call Canon, and hopefully they can send someone.
                  Thanks again!
                  • copier tech
                    • 8104
                    Thin black lines on most printers is caused by the drum.
                    We could recomend a local company to look at the machine for you, rather than call out Canon direct, where are you based?
                      • 22937
                      I don't believe that you read the title. Blank means no image. Thin black lines means undesired image. There is a slight difference. =^..^=
                      • Kendjr
                        • Dec 2014
                        • 8
                        06877 is my zip code.
                        • JPiek
                          • Oct 2014
                          • 435
                          Not sure about the 2270, but i suppose it has a bleu-stick/tool to clean the laserglass, like most of 'em ?
                          You could try, it takes a couple of minutes and could save you some money...
                          Blank lines lead-to-trail :
                          - dirt on laserglass (often 1 color)
                          - damaged drum (allways one color)
                          - Transfer issue (most of the time all colors)
                          Johan
                          • Brian8506
                            • 1658
                            If you can't find anyone close, PM me. I'm about 70 miles from Ridgefield CT and might be able to get up there within a couple days.
                            • Kendjr
                              • Dec 2014
                              • 8
                              It is a BW only printer. I looked in the manual, and do not believe it comes with the tool as you described. But thanks!
