irc3080 cyan and magenta missing. no codes
  • macuk
    • May 2009
    • 90
    [CQ] irc3080 cyan and magenta missing. no codes
    Hi. Have not worked on these machines in a while! I have an irc3080i that only prints and copies yellow and black. cyan and magenta completely missing.
    If I stop the machine during an autograd the rear patterns on the itb (cyan and magenta) are missing.
    I have swapped the two sub boards on the main controller to see if problem swapped between yellow/ black to cyan/magenta but no joy.
    Is this a main controller problem or do you think 2 lasers have gone at the same time?
    I have an old irc3080i at the office. Am I able to swap main controllers to test or will that kill both boards? If i can swap boards do I need to keep the sd cards with their original boards or keep them with their original machines? Any help appreciated!
  • ernesto
    • Oct 2011
    • 430
    Re: irc3080 cyan and magenta missing. no codes
    Hi it happened to me once...it was one pcb board inserted in the main controller...
    There are two equals you can swap them and if the problem is the board the black and yellow color will miss.....
    • macuk
      • May 2009
      • 90
      Thanks Ernesto for the quick reply. I have swapped the two sub boards around but the fault did not move, thats why I think it could be the main board
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Chack anyway laser assy especially two flat cables!
        • logonjim
          • 136
          Number of boards on the top right hand corner of the machine. Remove them all and clean contacts and re-seat them all and make sure they are all square . These can become unseated and cause weird problems
          • THUK
            • Jul 2008
            • 195
            Hi it could be the drive clutches for the two missing clutches.
            • SAZ911
              • Mar 2013
              • 193
              Hi Macuk,
              I had the exact same problem but with black,
              Please see link below, which helped me resolve my issue.
              http://www.copytechnet.com/forums/ca...-no-black.html
              Thuk could well be right.
              Cheers
              SAZ911..........
              • copier tech
                • 8174
                First I would work out if your c & m drums are driving. Draw a small mark etc on the edge of the drum, power cycle the machine & see if the marks have moved?
                • pinheiro
                  • May 2009
                  • 51
                  Hi
                  Follow the below:
                  If the symptom does not change after Re-fit 2 Main Controller Sub PRRM-EF-A PCB's and after interchange the upper and lower Main controller sub PCB's, replace the Main Controller PCB you will come right.
                  Regards
                  • pinkia
                    • May 2009
                    • 19
                    Originally posted by pinheiro
                    Hi
                    Follow the below:
                    Regards
                    Dear first of check whether your drums rotating by marking, check whether clutches of respective colors are rotating through service mode.
                    Second check whether mieler stop laser path over drum unit, you can check same by lifting respected drum units over your head and poping from down side of drum units.
                    Hope it might be work for you.
