Hi, guys need help in Minolta Bizhub 284e. The machine is newly installed more than a week but 2 days ago the user complain that the machine is not printing if the machine is in power save mode/sleep mode. They need to turn off and on the machine before the machine print the document. Yesterday i visit the location with the latest firmware but still the same problem. I'm new in KM machines, Any suggestion, thanks' in advance.
Printing problem.
Re: Printing problem.
First, try to change FW for SSD, I think that is GD1-A9. Try to find on Infohub.
If your problem is not resolved, change SSD Board, and put new FW G20-K1
I have the same problem, and I repair machine.
Regards -
think it's caused by power save settings, go to admin, system settings, power save settings, enter power save mode, change from "immediately" to "normal" then go to 2/2 change power consumption in sleep mode from "enabled" to "disabled"
seem to remember there was a bulletinTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
In tech rep mode you can enable disable sleep.
Then in admin mode turn sleep off.
I have replaced about 7 or 8 SSD boards and mfps to stop this issue.
Good luck.We know a thing or two because we've seen a thing or two.
The medication helps though...Comment
Firmware GD1-K9 purports to fix this issue. Give it a try. =^..^=If you'd like a serious answer to your request:
kingarther above is correct, seen this a few times, there was a bulletinLet us eat, drink, and be merry, because tomorrow we may die!
I also go to service mode to enable the setting to turn off sleep mode. Then in admin setting turn off sleep mode so that now it only goes into low power mode. Set immediate to normal. Also definitely turn off weekly timer.
Sent from my XT1254 using TapatalkComment
