C1060 Yellow issue.
  • DigiMan
    • Jan 2013
    • 262
    [Misc] C1060 Yellow issue.
    Good evening everyone
    Little to say here since i've just met the guy but i got this the other day and im about to go there tommorow.
    What do you gyus think?
    PS:Not entirely sure if hes using OEM toner or not.
    I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: C1060 Yellow issue.
    swap the dv units with another color and see. looks like a DV issue to me.
    • MADSYS
      • Sep 2009
      • 10
      Most of the times this failure is related to developer outage ( partially gone to the waste box ).
      The cause still not clear but you can find this somehow explained on Troubleshooting Guide V2.0
      A new F/W was recently released. Look for C1070all_gmw20.zip file on MKM website.
      Good luck !
      • DigiMan
        • Jan 2013
        • 262
        Goodmorning everyone
        When i got there yesterday the machine wasn't even working,it was popping C-2811.
        By pulling out the drum i noticed the mag roller on the yellow dv was completely drained.
        Tried to inspect the waste box but the client had alrdy cleared it out.
        Didnt find anything unsual inside other than the yellow/magenta drum and all the coronas are
        at 100%.
        Thinking about just changing the yellow dv for starters to get it working,but i still dont know the
        reason why the dv dissapeared.
        • wjurls
          • Feb 2017
          • 498
          Did you ever resolve this issue? I have a C1060L with the exact same issue. All 4 developing units and fresh developer were changed out 33K ago for regular maintenance. Now the yellow developer is low to the point of not covering the sleeve. Subsequent C-4631 and C-2811 codes. Other colors seem fine. Everything OEM.
          Lee
            • 23009
            Charge loss will make it suck developer. Start with your primary charge units and possibly drums. How many copies on these consumables?
            • wjurls
              • Feb 2017
              • 498
              Drums were all replaced about 60K ago, 33K ago all developing units, developer, charge coronas, and transfer belt, rollers etc (PM Kit) were replaced. Calibrations performed and Fiery Calibration completed. Machine only has 1 million total count.
              I will have to load fresh developer and double check all settings next visit. Firmware was pretty old. Flashed to latest level. Problem is only seen with the yellow DV.
              Curious what the OP finally did to resolve this issue.
              Lee
