FS-532
  • kenpio
    • Dec 2015
    • 201
    [Misc] FS-532
    Any instructions on how to remove the staple unit from this finisher? Looks easy, took one screw out and it looks as though there are 2 pins on the other side, does not move.
    KEN
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: FS-532
    2 screws 2 wire harnesses, a ground wire and the long screw at the bottom of the plate (with the nut on it) will lower the unit with plate 11 to come out of the keyholes and lift out.
    • kenpio
      • Dec 2015
      • 201
      Re: FS-532
      Okay sports fans, we got the staple unit in and it is doing the same as it was before, throwing a C-1109 error or a J-7281. Both concern PS40 and they are in the staple unit. Dont know where to go now? Any thoughts?
      KEN
      • Synthohol
        • 5849
        Re: FS-532
        was the one you installed new?
        try a new staple cartridge?
        tried firmware?
        reseat cables on FSCB or that swing arm junction plate for the 2 pin wire i usually forget to plug back in after removing the carriage??
        trace the wires back to the board and cut all the zipties?
        rotate the stapler by hand to make sure it goes all the way around?
        check CN130 and 131 for wire damage?
        if all those check out i would start thinking about an FSCB.
        good luck!!
          • 23009
          Re: FS-532
          If I remember correctly that's a staple movement error. My endusers can be a little rough, and have been known to tip the stapler on the rails, so it can't move. Just re-seating the stapler on the rails can be enough. On more than one occasion though they have bent various stapling tray parts so that they obstruct stapler movement.
          Just roll the stapler through it's movement to make sure that it clears all the other mechanisms. =^..^=
          • tech51
            • 846
            Re: FS-532
            Went down this road a couple of months ago.
            It turned out to be a broken wire in the loom running from the stapler unit to the frame.
            Either repair the wire or replace the loom.
            • Albonline
              • Sep 2008
              • 1151
              Re: FS-532
              also check icps on fnscb and stacker driver if it has one. your old stapler could have taken one out.
              • kenpio
                • Dec 2015
                • 201
                Re: FS-532
                Okay found the solution yesterday. Found that there was a broken wire, the power wire that was between the staple unit and the back of the stacker unit. We resoldered the wire and away we went. We are ordering a new harness in case other wires break. This unit has 13M on it!!
                KEN
                • antone
                  • Oct 2014
                  • 344
                  Re: FS-532
                  What is the loom?
                  Sent from my SM-N920V using Tapatalk
