Bizhub C360 stuck in hour glass mode
  • copiertec
    • Jan 2016
    • 2209
    I have a Bizhub c360 that is stuck in hour glass mode. I unplugged every option, usb, cat 5, adf, fax board and the HDD, I cleaned and re-seated memory Dimm and no change. I'm not even able to get into service mode. Is it the HDD? Any help would be appreciated.
  • Synthohol
    Certified Konica Expert
    • 5835
    Re: Bizhub C360 stuck in hour glass mode
    have you tried booting to a firmware stick?
    • copiertec
      • Jan 2016
      • 2209
      No, I haven't. I was contacted by the customer because the company that was out there prior, left the copier in that state and didn't return. I have access to firmware and service manuals,but I am not that familiar with Konica Minoltas,
      • Woxner
        • Jul 2011
        • 849
        This is useally the firmware gone wacko if not it could be mfp or ssd board. but firmware fixes this most of the time.
        Just copy the files from the folder to the usb root. dont worry about the ones outside the folder. nothing else should be on the drive. 2gb usb is recommended but 8 will work
        • copiertec
          • Jan 2016
          • 2209
          Thank you, Woxner, I appreciate the information. Being the MFP is stuck in this hour glass mode, will I be able to update the firmware or do I need it in a command mode?
          • Woxner
            • Jul 2011
            • 849
            once you put the usb stick in the service port and turn the machine on it will allow you to updated firmware it may take 5 minutes or so to boot so have a beer. no command mode
            • mearmi
              • Oct 2010
              • 350
              Update the firmware
              • habik
                • 2013
                I'd try Trouble Reset > Firmware > MFP Board
                Firmwares HERE
                • copiertec
                  • Jan 2016
                  • 2209
                  Well, I updated the firmware ( AOEDOVO-FOOO-GD8-D1) the MFP said it downloaded it, I turned it off from control panel, then front door switch, unplugged from the wall, removed usb stick, powered back on and still the same result. I tried firmware (AOEDOVO-FOOO-GOO-D2) with the same results. I noticed there is an NVRAM firmware (AEDOVO-0023-G80-85) but was reluctent to try that one. Should my next step be to replace the MFP Board?
                  • Woxner
                    • Jul 2011
                    • 849
                    next is mfp. dont take it from another machine. install it and turn on after usb with firmware is put in service port.
                    • copiertec
                      • Jan 2016
                      • 2209
                      Thank you, Woxner, I appreciate the information. I will the customer know its the MFP PWB (P# AOEDH02006) and go from there. I will post the end result.
                      • kingarthur
                        • 1364
                        When updating FW on this model, don't install scanner FW, it can kill the machine
                        • Don N.
                          • Nov 2011
                          • 409
                          We update every C360 with G00-D2 FW. Never experienced a "kill" and hope we never do!
                          I saved this procedure in case I have to use a used board sometime. I'm told it's the same procedure for all color machines, but need confirmation for this series.Precedure to fit a used MFP board Revision 6.pdf
                          • copiertec
                            • Jan 2016
                            • 2209
                            Thank you all for the responses. I sent the MFP PWB out for repair and received word from the repair company that the board was the issue but they are unable to repair it basically because of irretrievable corrupted data. Now I have to discuss with the customer if they want to pay the price for a new one, they are not cheap!
                            • Hansoon
                              • Sep 2007
                              • 3385
                              I sincerely doubt that any repair company is to be able to repair such boards. Besides probably from blown ICP's, how are they going to diagnose that very complicated electronics? Only way would be to hook it up to a same type of machine perhaps but that raises a doubt, they cannot have a testing machine for all brands and types. Besides of that where are they going to get the special dedicated IC's from? Power units could be diagnosed and repaired cause that's more or less standard technology not necessarily brand specific but not the logic boards.
                              Try to get a junker. They are cheap these days and contain lots of other parts. At least that's what we are doing.
                              Hans
