Fused unit error
  • tivzualuke
    • Dec 2016
    • 17
    Fused unit error
    I have changed my fusing unit more than 3times but not working, still showing error. What can I do.
    Sent from my Infinix HOT 4 using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Fused unit error
    More detail on the error please.
    Whatever
      • 22997
      My psychic powers seem to be slipping.
      What model? What error? Is there some other way that I could know this? =^..^=
      • tivzualuke
        • Dec 2016
        • 17
        Still requesting to install fusing unit after I changed about 3 different units
        • tivzualuke
          • Dec 2016
          • 17
          Somebody said I have to reset it there is a particular one that is already registered to the board they need to clear it first
          • MDR24
            • Apr 2013
            • 64
            If you want help you need to give the necessary information. Saying "you need to do a reset" isnt narrowing anything down.
            Whats the model of the machine?
            What error are you getting?
            Help us, help you.
            • tivzualuke
              • Dec 2016
              • 17
              Bizhub c253
              • tivzualuke
                • Dec 2016
                • 17
                • MDR24
                  • Apr 2013
                  • 64
                  Now whats the code your getting?
                  If the person you got your info from is correct and all your machine needs is a reset, there are 3 different ranks of machine reset Rank A,B and C. The rank depends on what reset you should do. To be honest though i don't see it being a simple case of doing a simple reset.
                  • tivzualuke
                    • Dec 2016
                    • 17
                    • tivzualuke
                      • Dec 2016
                      • 17
                      From there is doing nothing again
                      • MDR24
                        • Apr 2013
                        • 64
                        We have only started to do the Konicas from C280 onwards so missed these
                        Easiest way to check if the fuser is registering as an old unit is by pressing utility and then consumable life. If it is empty then follow the below instructions.
                        If they are like the C280s models it should just be a case of entering the service mode, select counter, select life, press new release then open the front door and highlight fuser then click the print key whilst the door is open. Once youve done that close the door and exit service mode.
                        That will reset the Fuser count.
                        • Elmo
                          • Feb 2010
                          • 541
                          Try using the search option on this forum
                          lots of info on this topic
                          but if your too lazy to search
                          http://www.copytechnet.com/forums/ko...nit-reset.html
                          based on your posts so far i recommend you get a qualified tech to do this for you
                          even google search comes up with answer
                          Konica Minolta Service Manual: How to reset the fusing unit - Bizhub C203 / C253 / C353
                          I Used To Live To Fix Things Now i Fix Things To Live
                          • tivzualuke
                            • Dec 2016
                            • 17
                            Thanks all. I appreciate your efforts and time.
                              • 8132
                              Once you get that message you cant fit used units you need to fit a new fuser unit as they have a quick blow fuse.
                              You can however cut off the fuse & replace it with a glass 80mA rated or lower, simply solder it in.
