BH C3110 disable replace imaging unit message
  • copier tech
    • 8169
    Hi all,
    Is it possible to clear this message without replacing the IU chip or replacing the IU?
    On the C35 there was a bulletin that with a FW upgrade showed how to extend the life of the IU's to 167% which worked great.
    I have a C3110 that is printing perfectly but asking for the cyan IU to be replaced.
  • Jonny
    • Nov 2011
    • 11
    Re: BH C3110 disable replace imaging unit message
    Its in service mode you can extend the yields as you said.
    Its under "IU Yields Settings" change from Standard to Extension
    This should give you 167 %
    • allan
      RTFM!!
      • 5462
      You can get the reset chips.
      Whatever
      • Synthohol
        Certified Konica Expert
        • 5846
        for reference...
        • Harjan
          Hi,
          Where is the chip of the drum? I can't find it.
          The drum lifetime is 25.000 and then hes stops with printing.
          I was wonder if the chip can be removed and then can be printing further?
          Tanks.
          • copier tech
            • 8169
            Originally posted by Synthohol
            for reference...
            I'm replying to my old post here, but this machine has the colour image units all showing 0% life remaining however its not showing a warning & is printing fine.
            I found this setting in CE mode (see pic below) with this enabled will the machine NEVER ask for the IU to be replaced!?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              [ATTACH=CONFIG]47339[/ATTACH]
              Don't have many of the small bizhubs and always use the extend life feature but have never seen that screen in pic before. Haven't seen a 3110 but have a few C35's & C3100P's. Will check and see if I can find that setting on these models. Might be it's only on the newer C3110 and why I haven't seen it?
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                We have a bunch of these POS machines and I've never seen that setting. Wonder what the exact path to that setting is.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • copier tech
                  • 8169
                  I totally agree such a POS model.
                  I updated the firmware & after was scrolling through the CE menu & found that option.
                  • Toxic
                    • 698
                    Also never see this option before.
                    Maybe FW version you put is the key, if you share that info?
                    • copier tech
                      • 8169
                      I've just checked the CE manual & this option is there!
                      Remind.pdf
                      • srvctec
                        • Oct 2009
                        • 827
                        [ATTACH]47351[/ATTACH]
                        But that is only for simultaneous replacement of all IUs, not the actual reminding of needing a new IU.
                        • copier tech
                          • 8169
                          Ah yes! ok I should have read my own post!
                          Still not sure why all the image units show 0% remaining but no message.
                          • srvctec
                            • Oct 2009
                            • 827
                            Me neither and I'd like to know how to make that happen since the print/copy quality is usually still fine when IUs reach zero percent.
                            • tsbservice
                              Field tech
                              • 8020
                              They're life extended that's why.
