BH C364e with FS-533
  • kenpio
    • Dec 2015
    • 202
    [Error Code] BH C364e with FS-533
    We have a problem with this model, actually it is the second finisher that we have had on this machine because we could not get the the error to leave. The error is that it says remove paper from paper tray in the finisher. The customer is getting a new machine and sending this to the leasing company, so it has to be working. We have the finisher in the shop and put it on one of our machines and the thing says that same thing, remove paper from finisher. Any ideas?
    KEN
  • wjurls
    • Feb 2017
    • 503
    Re: BH C364e with FS-533
    Check for a blown ICP on finisher control board.
    • kenpio
      • Dec 2015
      • 202
      Well just to let every one know, we found the problem. The paper actuator was flipped backwards. I guess the customer pulled the paper out when there was a jam and it says in the parts manual, the weight.
      KEN
      • kingarthur
        • 1385
        KEN
        There's a bulletin about a modified spring for this actuator....can't find it at the mo, but i have the springs p/no A2YUPPQ201
        • allan
          RTFM!!
          • 5462
          KEN
          It takes some doing to flip it over, wish i can get it on camera when they rip the jammed paper out of there.
          One guy needs to beholding the machine down or something.
          Whatever
            • 23010
            Something like this?:
            http://www.copytechnet.com/forums/ko...sher-tray.html
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              if it is the black plastic finger from the top flipped in the wrong direction this is very common. If the adhesive rubber strip on it is bunched up at the tip it will happen again and again. Just peel it off and it wont happen again - has never for me, or caused any problems.
