paper jam in biz 361
  • Gab
    • Aug 2015
    • 671
    When making one sided copies is ok. when make 2 sided but one copy is ok. When making multiple 2 sided copies usually paper jam occurs. Sometimew, very seldom, is ok. But usually paper jam occurs.
    One paper in the machine is just before the exit and the other paper is at duplex , at the back side. I suspect sensor . Any idea?
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: paper jam in biz 361
    clutches. im not working on KM anymore so I dont know part numbers, but i know it's clutches
      • 23009
      Jam codes? =^..^=
      • Woxner
        • Jul 2011
        • 851
        replace the two duplex clutches
        • Synthohol
          Certified Konica Expert
          • 5849
          another vote here for clutches!
          • Gab
            • Aug 2015
            • 671
            How to get in jam codes? I am Ricoh tech not so familiar with KM . I have the service manual
            • havokprod
              • Oct 2012
              • 159
              4th vote for clutches, also duplex drive gear will sometimes break a tooth and give you problems.
                • 23009
                Ricoh techs don't use manuals? Say it isn't so! =^..^=
                • Gab
                  • Aug 2015
                  • 671
                  There is huge distance between Rixoh and KM manuals. I mean is too easy to read Ricoh manuals and much more difficult for KM.
                  Inn searce i gave "jam code" and "jam" with no results/
                    • 14813
                    With KonMin service manuals just click on the "Troubleshooting" tab and all the jam and error codes are listed there. Easy peasy.
