biz hub 203 firmware card error
  • aeshen2
    • Sep 2016
    • 8
    [Dead] biz hub 203 firmware card error
    i got a biz hub 203 machine to repair the problem is machine not getting ready so i try to update the firm wear unfortunately card not working . so pl anyone can tell me wear i can get a card . pl any one can help me pl reply
    thank you
  • Woxner
    • Jul 2011
    • 852
    Re: biz hub 203 firmware card error
    internet
      • 14852
      It has to be 128mb compact flash. Anything larger will fail every time.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4730
        Also do NOT format the card! It will be unusable for this application.
        Are you using K/M Toolkit to write the F/W?
        Agree is has to be 128mb. Have used 256mb a few times but hit or miss. I know one brand that works is sandisk. Check ebay.
        • ck1
          • 485
          can some help me to get the CF card can use it. i buy a lot from ebay also error
          • copier tech
            • 8184
            What software are you using to copy the firmware to the card?
            • ck1
              • 485
              I using Firmware Imaging Toolkit 2006
              insert cf to machine show invalid card
                • 14852
                What size card are you trying to use?
                • copier tech
                  • 8184
                  This is what you need:
                  SanDisk 128MB CompactFlash Industrial CF
                  • Nommo
                    • Apr 2014
                    • 27
                    It is possible to recover a CF card. There is proper documentation, just look for it.
                    • ck1
                      • 485
                      128
                      • aeshen2
                        • Sep 2016
                        • 8
                        thank you so much
                        • emujo2
                          • Mar 2017
                          • 1579
                          If the card has been formatted for use in windows, it will NOT work in the MFP. The firmware toolkit will look like it's written the files correctly, but the copier cannot see due to the windows format. You can find free hex editor tools on the web, download and use the tool to overwrite the card 100% with 1/0s. This will remove any windows format then you can use the firmware toolkit to write the firmware to the card once again. Agree with the 128 MB size limit. You can always check the CF card by popping it into a windows slot. If you get a message "do you want to format this card" then it is either truly blank or has the VXWorks format needed for use with the toolkit. I have heard that others have has success with using a camera to do the same format. Not sure why, but KM took the format card option away with later versions of the toolkit, it's there, but remains greyed out. Emujo
                            • 14852
                            Not to be contrary, but I have formatted my 128mb SimpleTech compact flash card many times and it still works to write firmware to the C353 series machines. Maybe I am just lucky. I have formatted both with Windows and the Imaging Toolkit. I'm not suggesting others do this, but just giving my experience.
                            • 907tec
                              • 434
                              My understanding of FWToolkit2006 is that the "Write" function actually performs a vx format behind-the-scenes. I have been able to format my CF cards in Fat/Fat32 and then simply write the FW again using the Toolkit. Good initial test is to remove the CF card from your computer and then reinsert it: if Windows freaks out and tells you it needs to be formatted, you are on the right track.
