Bizhub C224 (Only black and white printing is possible)
  • lilleputte
    • Jan 2013
    • 153
    Hi.
    Bought a used machine. The machine says "only black and white printing is possible".
    Have tried to update firmware but without success.
    Any ideas are welcome
    // Thanks
  • copier tech
    • 8169
    Re: Bizhub C224 (Only black and white printing is possible)
    This is because your colour drums have exceed life.
    You can disable this message in CE mode.
    • HitMan
      • Aug 2015
      • 170
      When first entering service mode press stop zero then clear. There is a dc/dev or image unit/ something life button hit that then no stop. Also go into system 2 then the software switch setting for switch 55 has to read 00001100 which displays 0C and switch 51 to 1111000 which reads as F0.
      • lilleputte
        • Jan 2013
        • 153
        Thanks for quick response , will try this and come back
        // Thanks
        • wjurls
          • Feb 2017
          • 498
          Check and make sure user authentication is turned off. If former owner had authentication in use and just deleted names and left authentication enabled, color copies won't be an option.
          Lee
          The Copy Guys.
          • copier tech
            • 8169
            Drop us an email, all firmware & advice available
            https://www.copierfirmware.co.uk/
            • rrrohan
              • Sep 2011
              • 1977
              Pretty sure even with no stop turned on it still eventually forces you to replace drums
              • allan
                RTFM!!
                • 5462
                Jip had that today. All switches and setting was done and the machine just stopped printing color.
                Whatever
                • lilleputte
                  • Jan 2013
                  • 153
                  Hi.
                  Lifestop is set to "OFF" and authentication is turned off.
                  System software switches is also ok
                  //Thanks
                  • lilleputte
                    • Jan 2013
                    • 153
                    I'll do that
                    • copier tech
                      • 8169
                      No, with the correct settings the machine will run forever with out stopping or displaying a "replace IU" message.
                      Obviously the print quality with fail & eventually you will need to replace the IU's anyway.
                      • kingarthur
                        • 1366
                        That's what i've always thought, but after a period of time, you have to replace the drums....due to the machine stopping, it's happened to me a couple of times
                        • REGSIS
                          • May 2016
                          • 435
                          Utility/consumables life print list. What's the count (M) for color drums?
                          • mattguthrie
                            • Jan 2012
                            • 35
                            Lee
                            The Copy Guys.
                            This post saved my can today. Definitely worth checking. Thanks, Lee.
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4718
                              Glad it helped. I wonder how many end users this old post has helped over the years not to call for service?
                              Not saying it's wrong for end users to save money and all my machines, contract & per call consumables are turned off before I sell machine. But this is a reminder why this site should be for Technicians ONLY. How much other info do end users get from this forum not having to call for qualified service!
                              Hopefully all the donations to this site are coming from end users. It's a small price to pay for what they are saving!
