C451 Pico Fuse Location
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] C451 Pico Fuse Location
    We have a bizhub C451 fuser that we are trying to locate the reset pico fuse on the fuser/fixing unit. I swear it was on the end, however we seem to have all of the covers off and cannot locate it. Does anyone have some specific information for location or a picture by chance? Thanks in advance, I.T. guy back in Copier division
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5843
    Re: C451 Pico Fuse Location
    Side cover in a black rubber tube likely with zip ties is the green .063A fuse.
      • 8167
      If you install the life stop fw you dont need to worry about replacing the fuse on the transfer & fuser units.
      • Brett GS
        • Jun 2013
        • 154
        Under the cover the same side as the plug/connector its zipped tied,it is under a clear tube.
