454 firmware
  • copier tech
    • 8195
    #31
    Re: 454 firmware
    Did you have this issue before you updated the FW? Or were you updating the FW to fix this or another issue?
    โ€‹
    • devontug
      • Apr 2015
      • 99
      #32
      Re: 454 firmware
      To fix this thought it would master reset the defaults
      • habik
        • 2013
        #33
        Re: 454 firmware
        You need Konica Rep to help you on this one or try what Woxner suggested.
        Firmwares HERE
        • nassor
          • Sep 2017
          • 30
          #34
          Re: 454 firmware
          Originally posted by copyman
          either "select all" those files and move to thumb drive or copy and paste all those files to thumb drive. confirmed they all are the correct files
          Try to use different
          USB flash drive.
          • devontug
            • Apr 2015
            • 99
            #35
            Re: 454 firmware
            USB flash drive.
            Yeah I did thanks and i got it upgraded ....
            Have some CE password issues
            • devontug
              • Apr 2015
              • 99
              #36
              Re: 454 firmware
              Is there anyway to get into service mode through administrator mode? Or change CE password just a question I'm at a lost now ready for trying anything
                • 23010
                #37
                Re: 454 firmware
                You 'll need to call the hotline to get the CE password reset. They give you a code sequence. =^..^=
