454 firmware
  • devontug
    • Apr 2015
    • 99
    #16
    Re: 454 firmware
    Originally posted by devontug
    Trouble rest still asking for the pass word
    Admin password is also not accessible default password is not working ... I thought the firmware upgrade would set all password to default
    • copyman
      Owner / Technician
      • Sep 2005
      • 4629
      #17
      Re: 454 firmware
      what default password are you using? can be "12345678", "00000000", "9272927292729272". Also try inputting each password 2 times without a space.
      • devontug
        • Apr 2015
        • 99
        #18
        Re: 454 firmware
        Tried 12345678 twice and 9272xxxxxx twice will check the "00000000" and let you know
          • 22999
          #19
          Re: 454 firmware
          No big deal. Just set an encryption passphrase. It's not unusual for that to clear/reset when you've formatted the HDD. It's in the Admin Settings menu, let's see if I can find specific keystrokes:
          In Admin Settings > Security Settings > HDD Lock Password > enter 20 digit passphrase > Ok > re-enter passphrase > power MFP Off/On.
          It doesn't really matter what your specific passphrase is, as long as you can type it exactly the same on two separate lines. Essentially Konicas encrypt the data on the HDD with a 20 digit password to make it unrecoverable. =^..^=
          • devontug
            • Apr 2015
            • 99
            #20
            Re: 454 firmware
            I can't get into admin
              • 22999
              #21
              Re: 454 firmware
              What admin password are you using? Has it been changed? =^..^=
              • devontug
                • Apr 2015
                • 99
                #22
                Re: 454 firmware
                "1234567812345678" plus all the other default passwords I know ... is there a way to reset to default? Admin or CE password
                  • 22999
                  #23
                  Re: 454 firmware
                  Power Off/On. Three consecutive wrong tries locks the machine. =^..^=
                  • devontug
                    • Apr 2015
                    • 99
                    #24
                    Re: 454 firmware
                    Yeah I Kno ... but when it comes back up still don't know what to try... can it be rest to default?
                    • Synthohol
                      Certified Konica Expert
                      • 5804
                      #25
                      Re: 454 firmware
                      firmware should not have done this.
                      did you try and swap boards or something?
                      • Woxner
                        • Jul 2011
                        • 839
                        #26
                        Re: 454 firmware
                        you may need to use the reset tool now. there is a bulletin where to enter part of the serial and code to try and reset.
                        Use the numbers in the serial twice followed by 8 zeroes. An example for the bizhub C360 serial number is A0ED012020866. (Do not use the item number A0ED012portion.)
                        The unlock password using the above example is 02086602086600000000.
                        • devontug
                          • Apr 2015
                          • 99
                          #27
                          Re: 454 firmware
                          Not sure bought it used
                            • 22999
                            #28
                            Re: 454 firmware
                            Sounds to me like somebody else gave up on it before passing it along to you. =^..^=
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4629
                              #29
                              Re: 454 firmware
                              did you try "9272" 4 times ?
                              • devontug
                                • Apr 2015
                                • 99
                                #30
                                Re: 454 firmware
                                Yes I did
