454 firmware
+ More Options
Posts
  • devontug
    • Apr 2015
    • 99
    [Misc] 454 firmware
    Who can help me with this issue I have upgrade firmware for the printer listed above but I can't get the machine to upgrade at doesn't boot from thumb drive can't someone tell me what should be in the rood it the thumbdrive??
  • copyman
    Owner / Technician
    • Sep 2005
    • 4692
    Re: 454 firmware
    are you using USB behind small metal cover in rear? It won't work from USB on front right side near control panel, only movie F/W can be loaded there.
    Only file on thumb drive should be the .tar file
    • devontug
      • Apr 2015
      • 99
      Re: 454 firmware
      Yeah I'm using the port behind the metal panel that slides up
      • Woxner
        • Jul 2011
        • 848
        Re: 454 firmware
        what size is drive? may need to use a different thumb drive. not all of them work
        • copyman
          Owner / Technician
          • Sep 2005
          • 4692
          Re: 454 firmware
          Correction, the .tar file is for movie data.
          For regular fw you open yellow folder and copy and paste ALL the files onto thumb drive. plug into rear usb port and turn machine on. I've had to wait 5+ mins for it to show on display.
          • devontug
            • Apr 2015
            • 99
            Re: 454 firmware
            Sandisk 2gig
            • devontug
              • Apr 2015
              • 99
              Re: 454 firmware
              When I open yellow folder just copy those two?
              • Synthohol
                Certified Konica Expert
                • 5824
                Re: 454 firmware
                open the A2XK0Y0 folder and select all and thats what you copy to the root of the flash drive.
                • devontug
                  • Apr 2015
                  • 99
                  Re: 454 firmware
                  this is all I see when I extract file
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4692
                    Re: 454 firmware
                    either "select all" those files and move to thumb drive or copy and paste all those files to thumb drive. confirmed they all are the correct files
                    • devontug
                      • Apr 2015
                      • 99
                      Re: 454 firmware
                      Hey guys I upgraded the firmware now I don't have access to my CE password or admin none of the defaults wrk is there a way to reset this ?
                      • Synthohol
                        • 5824
                        Re: 454 firmware
                        i never saw firmware change that, what else happened?
                        • devontug
                          • Apr 2015
                          • 99
                          Re: 454 firmware
                          All I did was upgrade try to access my admin and CE and can't
                          • Synthohol
                            • 5824
                            Re: 454 firmware
                            boot holding reset and see if you can get to service mode after hitting trouble reset and format the HDD.
                            you can also unplug the HDD and wipe it on a PC and reinstall, format and install movie data.
                            try going into admin mode first because the option to format will be the first thing to pop up
                            • devontug
                              • Apr 2015
                              • 99
                              Re: 454 firmware
                              Trouble rest still asking for the pass word
