Hi all,
Looking for some assistance, I had a c8000 machine with Konica's ic-601 RIP, however, it was a source of frustration and we managed to get hold of a redundant ic-306. I reinstalled everything from the Fiery system software CD (new HDD in the RIP) but when trying to run prints directly from the RIP/CW5 it said there was a signed driver issue (can't remember the exact message).
However, everything loaded fine otherwise but when the job gets sent to RIP it will just drop back down from the processing tab. Going to 'properties', it says "Product is not enabled".
On checking CW5 Device centre, the graphic shows installed units that are not currently present (I'm guessing from the RIP's previous configuration).
At some point in the install it said to check the 'installable options' tab in the printer's driver - in this section, the graphic shows the correct units installed but the options window still shows incorrect units (unfortunately the add/remove buttons are greyed out). There's a '2 way communication' update button but this fails to connect - I should point out I tested that function on another (working) c8000 with ic-306 and it also failed on that, so I'm not sure that's the solution.
Can anyone suggest anything to update/clear the legacy? I've a number of Fiery system software CDs but I'm guessing they're universal?
Likewise, I'm guessing the legacy isn't in the dongles, as I've swapped finishing units on machines previously with no legacy problems.
I should note it prints the colour calibration chart from CW5, so it seems like a driver issue.
