bizhub 750 smudging
  • inkstrum
    • Apr 2011
    • 14
    bizhub 750 smudging
    2017-09-19 12.30.02.jpgbizhub 750 has small fairly light smudge in same place every 6th sheet of 11x17. ???
  • nassor
    • Sep 2017
    • 30
    Attaching ur images please
      Re: bizhub 750 smudging
      yes images needed... what has been done to it? did you pull all consumables and parts.. and clean the internals?
      • inkstrum
        • Apr 2011
        • 14
        A 250K PM was done 64,995 prints ago with all related parts cleaned.
        • nassor
          • Sep 2017
          • 30
          [ATTACH=CONFIG]37674[/ATTACH]bizhub 750 has small fairly light smudge in same place every 6th sheet of 11x17. ???
          check: Developer Unit, or Fusing unit.
            • 23008
            These machines are well known for dumping toner. There wouldn't by any chance be a large pile of toner in the separation transfer unit? =^..^=
            • Woxner
              • Jul 2011
              • 848
              looks like a drum or blade problem. check cl unit for backup as well. if its a non oem they last less. same with pm kit blades. also check the erase by the charge. i dont think its fuser. click on his picture in the message to see the issue
              • copyman
                Owner / Technician
                • Sep 2005
                • 4709
                Every 6th page don't make sense. Any internal parts, i.e. drum, fuser, etc causing smudges or marks would be every other page or at most every 3rd sheet. Something don't add up?
