C284e error C2253 after being transported to a new location
  • maksima
  • copyman
    Owner / Technician
    • Sep 2005
    • 4709
    Re: C284e error C2253 after being transported to a new location
    Since machine had a hard move I would look at the PRCB board for damage / cracks, or loose connector. Also anything binded.
      • 8164
      Dude if it has evidence of a rear impact you could be looking at a hairline crack on any board.
      Looking at your picture it looks like a fairly hard impact.
      Send it back to base/swap it out even if you fix that issue it could cause many headaches in the future!
      • maksima
        Thanks, most likely this is what I'll end up doing. Doesn't look like an easy fix. To bad this is a beast of a MFP.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4709
          They usually move ok without damage. I've had them shipped to me from hundreds of miles away and 99% of the time they are ok. And that's saying a lot if you saw some of the trucks & drivers!
          • maksima
            It depends if it is moved properly crated on a pallet vs ghetto style strapped inside a minivan. We got it ghetto style. With all the cartridges, drums, etc installed inside the printer. What are people thinking? Anyone with a service manual could share how to get to M2 motor?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4709
              All the machine I get always have the toners, dev units and drums left inside when shipped. I would rather have the consumables left in machine when transported. Better than being removed and drums exposed to light & dirt, Dev & toners mixed up between machines, etc.
              As long as machines aren't tipped over drums, toner, devs are fine left in machine.
                • 8164
                Here the CE manual but i'm not sure it will help!
                https://mega.nz/#!sAkXwKLZ!k-SWcEjzFeMFbAdq9wC4KzYjwQzByIxI-ymqYOuSzOQ
                • maksima
                  Thank you!
                  • Eresources
                    • Nov 2011
                    • 37
                    We recently had one shipped to us from another dealer and it was shipped laid down on the right hand door side of the machine, on a pallet. Apart from one broken panel and scratches on every other panel, it worked okay.
                    • cruzin
                      • May 2016
                      • 5
                      I am also experiencing this code after a long distance move. Did you find a solution to this?
                      • Synthohol
                        Certified Konica Expert
                        • Mar 2016
                        • 5835
                        I would remove the drum, developing unit and transfer belt and try turning them by hand. it's rare that a motor actually goes, it's usually a consumable that bound up because all the developer is towards the back or towards the front of the DV unit
                        good luck
