Imaging Issue on a 364E i have never seen before!
  • Estill0918
    • Sep 2017
    • 13
    It almost resembles tire tracks and shows up on Magenta & Black. I have replace the HV board, transfer belt, transfer roller , swapped out the consumables to check for improvement, firmware update , & checked the connections on the PCB. Still getting it. has anyone ever seen this before?
  • Estill0918
    • Sep 2017
    • 13
    Re: Imaging Issue on a 364E i have never seen before!
    here's some examples I am getting.
    • kenpio
      • Dec 2015
      • 202
      Looks like a developer unit.
        agreed
        • copier tech
          • 8184
          agreed
          Classic DV issue, check this first, simply remove the dev units & observe the dev coating.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4731
            I kinda like the look but hard to get a customer to accept that
            I was thinking DV but the poster said all consumables were swapped from another machine and it still did it. I'm assuming by consumables he meant drum & dv units.
              • 23009
              That's just what I was going to say. =^..^=
              • Estill0918
                • Sep 2017
                • 13
                I guess some don't know what consumables are.
                • Estill0918
                  • Sep 2017
                  • 13
                  meh
                  going to try the PH UNIT TOMORROW. it's happening on M C K and nothing on Y
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4731
                    It's gotta be the PH unit. Can't think of what else could cause that effect. Especially since you say yellow isn't doing it if you run just a single color test page. I've also seen some wild patterns from charge grids shorting, etc, but not like what you have.
                    • copier tech
                      • 8184
                      • habik
                        • 2013
                        Replace drum and dev with new units at the same time!
                        If any other units over life, replace them.
                        Firmwares HERE
                        • printerguy77
                          • Feb 2014
                          • 26
                          I'd hazard a guess that you are using compatable toners and probably Katun at that.
                          this nearly destroyed my fleet of Olivetti MF222 -MF452. do not use it under any circumstances. savings are not realistic as the amount of drums developers and ITB's that need to be replaced as a result not to mention the heart ache of the customer and the extra engineer call outs and fuel wasted dont add up.
                          • Estill0918
                            • Sep 2017
                            • 13
                            Consumables
                            Consumables are parts you have to replace on standard maintenance , it's the actual term the manufacturer uses for the parts. Sorry for the confusion.
                            • Oystercopy
                              • Oct 2009
                              • 623
                              I didn't notice this in the thread, but does it do the same thing on PRINTS as well as copies?
                              If it is, I had one machine recently continually suck the developer out of the black unit, even though I kept replacing them.. We thought there might have been something wrong with the HVT, but replaced that as well, and same problem. It was likely something in the logic that was causing it, but I ended up replacing the whole machine, because I'd lost so much money on it already... and those DV units are NOT cheap.... you could destroy a lot of them in the process and I think they're about $500 each!
                              OC
