Bizhub 240f, firmware
  • Hansoon
    • Sep 2007
    • 3350
    Anyone able to send me the firmware for the KonicaMinolta 240f please? Machine is stuck on the KonicaMinolta logo and doesn't continue booting. Seems I need FW:
    MB-750 Firmware version B9A0A0
    OP-700 Firmware Version A5A0A0
    Konica Minolta 240f Firmware Version D4A0A0
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • copyman
    Owner / Technician
    • Sep 2005
    • 4539
    Re: Bizhub 240f, firmware
    Are you sure about that model #? I don't see it listed on the K/M dealer site. Perhaps it is only sold in Europe?
    • allan
      RTFM!!
      • 5459
      Wow what is that?
      Whatever
      • Hansoon
        • Sep 2007
        • 3350
        Its originally a Muratec which is being sold in Europe as Bizhub-240f.
        Would the firmware only be available on the Europe Website??
        Hans
          • 8105
          Dont see these little boxes very often.
          Here's the FW.
          https://mega.nz/#!BdkSjaJR!CDT90aLO8ttl6AT1qVX0D2buetMLCwh3NBhMOOx 07TY
          • allan
            RTFM!!
            • 5459
            RICOH 1515 in the blood.
            Whatever
            • Hansoon
              • Sep 2007
              • 3350
              Here's the FW.
              Got it. Thank you very much.
              BTW: Wish you guys would get rid of that Brexit.......
              Hans
              • Hansoon
                • Sep 2007
                • 3350
                Don't think so Allan. Its basically a Muratec 2550. Even its Webinterface is showing "Muratec"
                Hans
                • Hansoon
                  • Sep 2007
                  • 3350
                  Until now I was able to revive the little beast two times with installing the firmware. Now it is not even accepting that anymore. The progress bar hangs in the last 10%. Machine is in a very hard to reach location, 7 stairs to climb, otherwise I would have replaced since long.
                  Any ideas? I have another working scrap machine to cannibalize for boards....... or better use it as Boat Anchor?
                  Hans
                  • Toxic
                    • 694
                    I had one restarting problem (boot loop) on 240f and solve with replacing cf card from other scrap machine and it works.
                    Do not know is that your problem but just a hint.
                    What firmware version you have now?
                    You tried few different usb memory for firmware upload?
                    • Hansoon
                      • Sep 2007
                      • 3350
                      Changed the CF-Card and machine came up. However there was an error message "501" firmware not matching. Tried to update the FW on that CF-Card from the scrap machine but it says "NG"
                      The firmware available to me is:
                      240f_EUR_D0A0A0_update.bin
                      240fEUR_Ver.txt
                      and
                      FWUD.bin
                      MB750_Ver.txt
                      I use a 2GB USB Stick
                      Any help please?
                      Hans
                      • Toxic
                        • 694
                        About the 501 error,it could be different firmware version on current machine and donor machine cf card.
                        Check and match all 3 fw versions 240f,MB750,OP700
                        Try to get cf card back to donor machine and update firmware to be the same versions as on the other machine and try then replacing cf card again.
                        When you get NG during did you check error code ? (The datailed errror code will be displayed when you press <Setting>, <*>, <9>, <8>.)
                        If not try to disconnect lan cable before firmware update.
                        Also try manual mode method fw update if auto not working.
                        • Hansoon
                          • Sep 2007
                          • 3350
                          The little creep is back on his feet. Changed the CF-Card and updated the firmware once again but now more careful than the 1st time.......
                          Thanks for your help guys.
                          BTW: I have following FW, are these the latest & greatest, or is there "better" ?
                          240f_EUR_D0A0A0 and
                          MB750_B9A0A0
                          But unfortunately not the PCL OP700_EN
                          Hans
                          • Xthedev
                            PLEASE the mega link provided is no longer working and i need the firmware file. Anybody...please
                            • mbr002
                              • 3
                              Is anybody able to send me the firmware for the KonicaMinolta 240f please? The machine shows the logo and stops with MB system error 12500. At CF card is written MB-750 - B3A0A0, before failure the machine reported
                              Main 240f EUR E4A0A0
                              Network MB750 C9A0A0
                              PCL OP700 EN B1A0A0
                              It seems to be a problem in network section, the checksum is missing.
                              Thank you
                              Martin
