Konica BH 223 283 423 fuser units having issues?
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Installed a brand new oem fuser unit from Konica and it had a flat spot on the lower roller which caused a thumping noise. Did a return RMA with Konica and they sent out another brand new fuser unit. No thumping or flat spot. But customer called back and the unit is fusing poorly/image rubs off a little. Like most tech's have seen when there is not sufficient pressure between the lower and upper rollers. I did increase fuser temp in service mode to compensate for the poor fusing but issue not completely remedied by that. Question: has anyone else been experiencing problems with brand new factory origional fixing units for these models?
    The only bulletin on fuser issues I can find pertains to the fusers prematurely wearing but nothing on an issue with brand new units bad out of the box:
    Description
    Marks on copies/prints.
    Solution
    CAUSE: Upper fixing roller premature failure due to scratching of the teflon coating by the thermistor and/or fixing claws. This might be due to improper
    fusing, causing toner and paper dust to adhere to the thermistor/claws.
    SOLUTION:Replace the fusing unit (p/n A1UD R709 11), then increase the fixing temperature on the machine.
    1. Enter Service Mode.
    2. Touch [Machine] g [Fixing Temperature].
    3. Select Plain Paper and change setting to 5 degrees C.
    Note : The fixing claws should also be checked and cleaned at every service call.
    Customers origional fuser only had an issue with a scored upper roller,no issues with fixing or noise. Certainly 2 bad fuser units in a row seems excessive----any feedback much appreciated.
    • 14813
    Re: Konica BH 223 283 423 fuser units having issues?
    Description
    Solution
    I installed a brand new OEM fuser a couple weeks ago with the same issue, not fusing properly. I slip a piece of paper between the rollers and one side had no resistance. I ended up disassembling the fuser and the one pressure lever was caught on the frame of the fuser. Once I corrected that it worked properly.
    • srvctec
      Former KM Senior Tech
      • Oct 2009
      • 827
      No issues here yet but we rebuild more than replace with new AND the rebuilt ones last much longer because the aftermarket rollers we use are way better than stock.
      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
      • Woxner
        • Jul 2011
        • 851
        only had press spring pop out of place during shipment. repaired it a was a ok.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4723
          Agree the aftermarket UFR is much better. I only rebuild with new UFR & thermistors. The brown UFR's seem to last much longer. The OEM & some other black rollers look like they are spray painted with no teflon!
          • CraigW
            • Dec 2010
            • 417
            Some good tips on a fix.
            So sad that 200-350s would last 500k + without a mark.... these get marks and lines at 80-100k.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              You are right Craig. Even though the black UFR rollers look the same as the older models, 200/250/350 something must have changed with 223 fusers because as you posted they crap out before 100k.
              Also I have a friend that has been having issues with the fuser lamps in the 223 series. Actually he posts on this forum and may have even addressed this issue before.
              I'm sure this all has to do with the OEM trying to save a few dollars by going to cheaper materials!
                • 23009
                On the 423's they only get manufacturers 50% of yield at best. Like clockwork. =^..^=
                • allan
                  RTFM!!
                  • 5462
                  If its 3de party toner it could be the problem, not enough or to much resin in there. Else if the combination of your mag brush being to thick and the dev being over-toned, the result could be similar.
                  They have put the thermistors onto spring brkts at the end, but its not the pressure that scratches the roller its poor thermistors. I remove the OEM ones and change them with working 3de party spares. You can rebuild those units until the fall apart. Its a 1/4 of the cost of a new one and the parts last 400K +.
                  Whatever
                  • REGSIS
                    • May 2016
                    • 435
                    I clean thermistors and separators every 20k. OEM UFR lasts around 200k.
                    Katun UFR (brown) lasts longer than OEM and price is 1/10 of new unit.
                    With one replacement, new fusing unit can easily lasts 500k.
                    I never replaced thermistors.
                    • blazebusiness
                      • 1257
                      Thanks for all the replies. I am surprised Konica has no removable tabs keeping the pressure off the lower roller until the new unit is installed. That would have prevented the flat spot issue on the first fuser we were sent. I did see that the customer is using a generic toner which I would not normally find suspect with an issue like this -- but I noticed there is some unusual toner adhering to the drum surface in between copies. I will install an oem toner on monday and see if there is any change in the fusing and overall copy quality. I'll get back and let you know what the fix was. Thanks again.
                      • blazebusiness
                        • 1257
                        Installed a new oem toner in the morning. Went back to the account 5 hours later. Fusing now much improved. ----------- The issue was a bad generic toner. Sure did seem like a fuser issue though.
