c224e counter reset
  • enricocopyline
    • Jun 2018
    • 121
    #46
    Re: c224e counter reset
    sorry.
    the reset of the meters serves for a robotics project not to make fraud
    I'm a robotic engineer
    I know a lot of electronics
    can you help me please?
    • Synthohol
      Certified Konica Expert
      • 5798
      #47
      This forum is for technicians working on copiers, perhaps you can email Konica minolta and see if they will help you with your project.
      I'm gonna have to pass on this one.
      • enricocopyline
        • Jun 2018
        • 121
        #48
        do you think konica minolta helps me?
        I will leave everything or change the type of photocopier.
        I do not think it's so complicated to explain exactly how to do it since they put a procedure in this forum but it's not really the right one.
        I do not ask for a public thing I ask in private.
        I tried to do a procedure but I did not arrive at the reset.
        • tulintron
          • Jul 2014
          • 669
          #49
          Good afternoon. If you convince me because you need the reset counterin robotics, maybe I can help you.
          NVRam only stores equipment data.
          Will you use the equipment after the reset?
          I would like to understand better.
          https://www.copytechnet.com/images/smilies/cool.pngNada como dia apรณs diahttps://www.copytechnet.com/images/smilies/cool.png
          • enricocopyline
            • Jun 2018
            • 121
            #50
            the machine will not be used after reset.
            the machine does not work even now because drums and other consumable pieces have already been removed.
            I need to start with zero counts.
            if you can help me thanks.
            in private, I understand they are not legal and can not be divulged.
            • enricocopyline
              • Jun 2018
              • 121
              #51
              can anyone help me?
              even in private ....
              • Zesti
                • Jun 2009
                • 308
                #52
                Copy Line
                I'm an electronics engineer, I can also understand ur request COPY line, will u pl. explain a bit the project of robotics. May be I can suggest u better way out.
                • enricocopyline
                  • Jun 2018
                  • 121
                  #53
                  robots are packaging robots. I need to reset because the machine counts must start in step with the robot counts. For this to do some tests I studied the Konica 4 series for their reliability and to change the copier I would have to redo all the projects from scratch.
                  other photocopiers it is very easy to start the counts from 0
                  do the reset I need on these two photocopiers to do the tests of the operation and no fraud is enough.
                  sorry for my English.
                  • asdexed
                    • Jan 2020
                    • 4
                    #54
                    Sorry
                    • tsbservice
                      Field tech
                      • 7972
                      #55
                      Originally posted by asdexed
                      Hello! I can count to 0 or the number entered.
                      All models !!! C250I c224e 224 223 s.t.bPrice: 2500 GBP . Pay Pal
                      Hello! I can count to 0 or the number entered. All models !!!Price: 2500 GBP to huf!
                      Usually I don't like to use red flags but this one is an exception. Reported also!
                      • Copier repairman
                        • Aug 2019
                        • 86
                        #56
                        in usb1 and usb2 are there any recovery firmware? Where can I find them?
                        A new ssd and mfb reset tool dove li trovo?
                        USB1 : A1UDFW.tar
                        USB2 : bizhub C224e NVRAM reset tool
                        A0P00Y0-F000-GQ7-D1.exe
                        A1DM0Y0-F000-GQ7-D1.exe
                        A0ED0Y0-F000-GQ7-D1.exe
                        A2WU0Y0-F000-GPD-F9.exe
                        A1UD0Y0-F000-GQ7-D1.exe
                        Happy New Year
                        • asdexed
                          • Jan 2020
                          • 4
                          #57
                          Its very easy counter modify. ALL 4 method can
                          • habik
                            • 2013
                            #58
                            Are you saying that the logic you incorporated into your robotic packaging system needs output from copier as count 0 ?
                            Why can't you just use the standard counter system that was developed by the manufacturer specifically for this reason, where you can reset the count at which ever point you want! No need to fuck with FW or SSD or eMMC's.
                            Sent from portable device using fast cheapset!
                            Firmwares HERE
                            • asdexed
                              • Jan 2020
                              • 4
                              #59
                              No need to replace anything. You need 1 laptop or a flash drive.
                              Counter is 0 because it is a hiring machine. Easier to bill.
                              • habik
                                • 2013
                                #60
                                What a lot of tosh...
                                Can you count to 21 with both hands and both feet?
                                Firmwares HERE
