c224e counter reset
  • xender79
    • Nov 2009
    • 47
    c224e counter reset
    c224e Meter counter reset?
    Help me
    wotjq79@naver.com
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: c224e counter reset
    can't be done. you're not the first to ask.
    copiers are often resold so the meter count is protected by law.
    • Zesti
      • Jun 2009
      • 308
      Somebody pl. help out xender79's innocent request.....
      BTW Xender it can't be done. Order new NVRAM.
      • Tech Helpdesk
        • Jul 2015
        • 112
        It can be done but it is all down to timing.
        1 -- Remove from machine[
        2 -- Place into microwave
        3 -- Set microwave to 900 watts power
        4 -- Set timer for 224 seconds (no more otherwise damage may occur)
        5 -- Press start
        6 -- When complete remove from microwave and refit
        QUOTE=Zesti;585357]Somebody pl. help out xender79's innocent request.....
        BTW Xender it can't be done. Order new NVRAM.[/QUOTE]
        • Elmo
          • Feb 2010
          • 541
          If it was such an innocent request he would be better explaining his problem and why he would need the counters reset
          he may get some help
          most likely he wants to zero a machine to sell it as new
          in this case he will get no help
          I Used To Live To Fix Things Now i Fix Things To Live
          • Albonline
            • Sep 2008
            • 1151
            Help me
            wotjq79@naver.com
            replace, at the same time mfp,mc and ssd. voila, you got a new machine that you can rip somebody off with, good luck!
            • Zesti
              • Jun 2009
              • 308
              Wow....that easy.....Xander go for it.
              Sent from my RHYTHM RX60 using Tapatalk
              • habik
                • 2013
                5 -- Press start
                [/QUOTE]Tried it and now the machine comes with 0 00000 on counter but its c coding with C164.
                Has anyone got the latest firmware?
                Sent from my Mi A1 using Tapatalk
                Firmwares HERE
                  5 -- Press start
                  [/QUOTE]
                  LOFL.
                  I hate when people try to screw a customer by trying to Zero Value the counters... totally dishonest
                  • habik
                    • 2013
                    Help me
                    wotjq79@naver.com
                    I'll tell you for 2 Ƀ
                    Firmwares HERE
                    • Zesti
                      • Jun 2009
                      • 308
                      Guys, tell you what. I got a BH363, the tech was stuck to clear the password. He messed up the NVRAM. When I fixed, the counters were 0000000.
                      • copier tech
                        • 8169
                        NVRam firmware if used incorectly will clear the main counters
                        • Zesti
                          • Jun 2009
                          • 308
                          Nop....BTW how to use NVR fw incorrectly?
                          • copier tech
                            • 8169
                            Not using it in the way it was designed for
                            • Zesti
                              • Jun 2009
                              • 308
                              Hmm..I'll dig deeply. But what about license management error.?
