c224e counter reset
  • jabatt
    • Apr 2014
    • 15
    #31
    Re: c224e counter reset
    [QUOTE = arahael; 704698] 영국에서는 미터 카운터를 재설정 / 복사하는 방법도 알고 있습니다. 전기 카운터는 기계보다 훨씬 낮습니다. 웹에서이 정보를 쉽게 얻을 수 있습니다. 나는 그들이 c258을 해킹하려고 노력하고 있다고 생각한다 . [/ QUOTE]
    * Bizhub C284 or C284e SSD COPY Tool
    * Bizhub C225 or C258 SSD COPY Tool
    • enricocopyline
      • Jun 2018
      • 122
      #32
      Hello
      does this procedure set to zero both as bk and color and all counts of electronic counts?
      • Synthohol
        Certified Konica Expert
        • 5847
        #33
        Yeah will this product help me rip off my customers as well?
        I mean if I have a machine that has half a million on it but I want to rake a customer over the coals and sell it as new, will this also help me sleep at night knowing damn well I'm a criminal?
        Yay fraud!!!
        Asshat....
        • robinsa
          • Apr 2017
          • 1
          #34
          You can clone the counter from another machine with a new ssd and mfb reset tool. The procedure is simple.
          • enricocopyline
            • Jun 2018
            • 122
            #35
            in usb1 and usb2 are there any recovery firmware? Where can I find them?
            A new ssd and mfb reset tool dove li trovo?
            • Synthohol
              • 5847
              #36
              you find them when you are a konica dealer and get support and downloads.
              zeroing the meters for what reason?
              • jotunn
                • 618
                #37
                This thread should be closed/removed... This is heading in the wrong direction.
                • enricocopyline
                  • Jun 2018
                  • 122
                  #38
                  zeroing the meters for no reason. just for information.
                  A new ssd and mfb reset tool where do I find them?
                  • femaster
                    • May 2011
                    • 1514
                    #39
                    The Knowledge base articles I refer to in my last post have links in them to the tools. Follow the links and you will have the tools you are after.
                    Sent from my XT1254 using Tapatalk
                    • Synthohol
                      • 5847
                      #40
                      It seemed to me he wanted to zero the counters for nefarious reasons so I decline assistance.
                      • jotunn
                        • 618
                        #41
                        [QUOTE=enricocopyline;707003]zeroing the meters for no reason. just for information.
                        There is always a reason for zeroing counters.
                        This knowledge is completely useless for a field service technician, servicing and maintaining the machines from commissioning to disposal as a result of normal wear and tear.
                        Moreover, I can't remember (maybe due to memory gaps) if I ever need "forbidden knowledge" to solve even non-standard issues - I mean, even non-standard issues could be solved with standard tools and knowledge.
                        Of course, there are some issues (like C-4801), that you hope to solve with "forbidden knowledge", but no, you can't repair them this way...
                        Most of really non-standard issues you can meet during rebuilding crashed machines - replacing construction parts, wiring, boards (with boards from another machine, not new one), adjustment of skewed scanner or PH unit, and so on.
                        But most of them comes from your own lack of knowledge, ignorance, or intentional skipping necessary steps - in these cases (this rather trivial and basic knowledge, from my point of view) will not help you to pretend to be a better technician.
                        If you really want this knowledge to fullfill your own curiosity, you must devote your free time (thousands of hours) to studying documentation, patents, electronics, building operating systems...
                        Then, one day you will be able to assess whether it was worth sacrificing...
                        Yes, you will be proud... Yes, you will know that C-E301 in not completely mysterious "referring incorrect memory" error, but just kernel panic due to memory leaks in heavily memory-optimised embedded system...
                        But then, when you realize that you can't repair machine even with such knowledge, you start to think that time you have spend on your studies is completely lost...
                        PS.
                        I just recalled, when I had to use "forbidden knowledge" - when I got machine (2nd hand, with total 38 copies) with unknown service password, and usual way (resetting with KM code) failed.
                        Then I found better way - not resetting, but recovering lost passwords.
                        So, how much $$$ would you like to pay for "forbidden knowledge" to cheat customers?
                        • tsbservice
                          Field tech
                          • 8020
                          #42
                          jotunn, such a great post and what a waste of time. Anyway thoroughly understand your frustration of some people being...beep!
                          • Zesti
                            • Jun 2009
                            • 308
                            #43
                            Fully agree with Jotun, most techs don't realize how much it takes to undetstand technology, they simply ask complex questions so simply. They don't bother to understand technology, sure they earn more....
                            • enricocopyline
                              • Jun 2018
                              • 122
                              #44
                              nobody wants to cheat, I need it only for other reasons, the reset of the counts are a robot and electronics engineer I know enough. I just wanted to know the exact procedure to reset the counts.
                              can anyone help me in private? thank you
                              • Synthohol
                                • 5847
                                #45
                                sure, i'll bite...
                                what does that mean exactly?
