C451 Printing issue, Black Imaging Unit?
  • Eko
    • Mar 2018
    • 11
    Hello. So this Copier was delivered to me about 2 months ago. It was free because it had a "bad transfer belt" and i figured I could replace it. However when i print it seems to have a different issue where the black is not working right. The other colors work fine when doing color tests but when I print using black it is all messed up. I changed the transfer belt anyways and the problem continues, does this look like a bad Black Imaging unit to anyone here?
    I only ask because these parts are expensive and I can't afford to throw parts at it without others opinions
  • Woxner
    • Jul 2011
    • 830
    Re: C451 Printing issue, Black Imaging Unit?
    its a bad drum or dev unit. it amy have dumped dev
      • 22973
      At what interval does the pattern repeat, in millimeters please? =^..^=
      • Eko
        • Mar 2018
        • 11
        The Drum and Developer are combined on this unit right? It did indeed dump developer, I have opened the copier and cleaned out all the dumped developer from the black unit.
        Which pattern, from the drum/Imager or the test patterns I used?
          • 22973
          If you don't see a pattern I don't think that I can help you.
          • Eko
            • Mar 2018
            • 11
            Ease up a bit. I'd rather ask you which pattern you want instead of guessing. I'd rather have clarity
            Based on mentioning L1600 I assume you mean the little white lines in between the fade color bar test?
            I'm loading from tray 3 so it feeds the paper landscape into the transferbelt
            EDIT: You mean the ring like imprints that almost look like the Audi logo?
            • copyman
              Owner / Technician
              • Sep 2005
              • 4571
              This is a very common issue with that model. There was a bulletin for dumping black developer. There was a mod to install a bracket to hold the Black Image unit in tighter, the problem was it would back out a little making a loose connection then it would dump. Good idea when vacuuming out the developer, also pull out the laser unit and vac dev off of that.
              • Eko
                • Mar 2018
                • 11
                I vacuumed all the Dev out I could with an industrial vacuum, then blew the remainder out using 90 PSI of air from a compressor while outside. The black unit does feel lose, I put a copper 2mm shim between the Black unit and it's mount arm for now and it's not lose anymore, it's very tight but It didn't improve the conditions(granted I'm sure the black unit is missing developer now)
                • Eko
                  • Mar 2018
                  • 11
                  So you want the measurement of the ring pattern?
                  • copier tech
                    • 8121
                    Yes I agree as has been said here, you'll need a new black IU, very expensive & even after you replace it the same issue could return.
                    Personally I would scrap this machine & not waste any time or money on it.
                    You can pick up copier cheap on ebay, look at the Bizhub C224/e series a good reliable model with excellent print quality, cheaper to maintain too.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4571
                      If you replace the black dev unit make sure you install the mod or it will dump again. There are 2 mods, one is the bracket I mentioned in my earlier post and the other is to build up pad on blue handle to push unit into machine tighter.
                      If you PM me your email I'll send you the 2 bulletins addressing this issue
                        • 22973
                        Oh ... how about this pattern?:
                        • Eko
                          • Mar 2018
                          • 11
                          I picked up this copier for $0, so I'm not overly concerned about putting a little in. The machine was delivered to me by the State of Nevada as it's one of the old State office Copiers.
                          I can pickup a brand new black IU from a supplier locally for 250$, then mod the unit to have some tighter grip. I'd rather repair it than junk it considering it's not that bad a machine
                          • Eko
                            • Mar 2018
                            • 11
                            [ATTACH=CONFIG]39553[/ATTACH]
                            Blackcat, that is the gradient pattern I printed on the copier when testing it, that pattern is from the test pattern menu gradient test.
                            It's supposed to print 5 bars of black, each slightly brighter than the last
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4571
                              That model is very old! you should be able to find a black DEV unit for less than that. ebay, etc
