KM Firmware naming
  • tsbservice
    Field tech
    • 8082
    KM Firmware naming
    Hi All,
    I'm still learning this brand and have difficulties to understand KM Firmware name convention.
    For example I have Firmware G00-R9, went to machine with Firmware G00-54and need to know which one is newer.
    Could someone shed some light to me, please.
    • 15071
    Re: KM Firmware naming
    Hi All,
    R9 is newer.
    • Synthohol
      Certified Konica Expert
      • 5922
      normally numbered FW is older than FW with a letter and even that is in alphanumeric order like J8 is older than M0
      the other snag is specil FW is all over the map but normally special FW is named GM6-## instead of G00.
      only looking at the FW list on KM is the right way to "age" the FW.
      • mo0651
        • 1054
        I think this is where Konica Minolta really struggles. I go by date released. READ all the README files. Half the time you can find special things in the regular firmware. and firmware you
        should have in the SPECIAL firmware. (movie data). It changes between models and who programmed it.
        I liked Toshiba when I worked on them It would be like 123A, 123B, 123E. Then 124A, 124B.
        • rrrohan
          • Sep 2011
          • 1977
          Not to mention all the different function versions.
          I dont bother with firmware unless it's going to fix something that customer is concerned with
          • kingarthur
            • 1399
            KM did produce a sheet a few years ago explaining how the FW was labelled, it might be on the infohub, if you go to the infohub and type in "SAL" and then select the model number, the latest FW will always come up, I've started to keep all versions of FW for each model now, as a couple of machines. i've had to roll back a couple of versions to get rid of problems caused by updating
            • CraigW
              • Dec 2010
              • 417
              ^^^ Can you point me to infohubs location ?
              Thanks !!
              • tsbservice
                Field tech
                • 8082
                Thank you all guys, especially to Synthohol and kingarthur.
                As so far I don't have access to Infohub, I was forced to work only with machine's firmware and those I received(supposed latest, but not
                necessary).
                Soon should gain rights to access Infohub and it will be easy
                P.S.
                With regard to Firmware updating I used to keep machines(Toshibas) at one version before latest(to avoid unexpected bugs/loops).
                I'm not familiar with KMs, but with Tosh(and they are also Jap) keeping machines at new Firmware level solved us a LOT of problems - existing and possible.
                True, we failed
                miserably in few occasions, but nevertheless I plan to do it that way with KM.
                  • 15071
                  necessary).
                  P.S.
                  True, we failed
                  If you are dealing with an 8 series machine, R9 is not the latest version. There is a U8 version available now.
                  As a tech, I like to keep the machines in my area up to date with base firmware at least. The special firmware I don't install unless I am experiencing one of the problems it was issued for.
                  • Woxner
                    • Jul 2011
                    • 854
                    one thing about firmware is there are fixes that are not listed in the list of fixes. i had problems with a hospital program they use. turns out special firmware fixed it. but this was not listed. i wont install latest until its out for a month. minolta trainers said samething.
                      • 23010
                      Originally posted by Woxner
                      ... i wont install latest until its out for a month. minolta trainers said samething.
                      That's smart. I came to the same conclusion another way. I happened to be working on a shop machine that our office staff uses, and loaded the latest (today's) firmware. Later that same day I started getting calls from everyone in the office: "Why doesn't the fax work any more?!" The next morning I downgraded the firmware to restore the fax function. Since then I test new firmware on an office machine whenever possible.
