Trouble shooting - fs532 j-7229
  • ysshin79
    • May 2017
    • 37
    ☆ Trouble shooting ☆
    ※ Symptom - Intermittent finisher JAM (J-7229) occurred
    ※ Model with FS-532 Finisher
    KM bizhub PRO 951 PRESS 1052,1250
    ※ Cause - Finisher exit sensor JAM occurs when the paper badge can not be detected due to contamination of the light receiving part.
    ※ How to handle - After cleaning the part appearing like a black non-woven fabric under the exit sensor of the finisher (responsible for the exit sensor sensor), solve the symptoms.
    ☆ ☆ If you continue to clean the light-receiving part, J-7229 symptoms will not be treated even if you clean it later.
    Applying the light-receiving part with black oil magic will make it completely processed.
    Or replace the non-woven material parts of the light receiving part.
  • ysshin79
    • May 2017
    • 37
    Re: Trouble shooting - fs532 j-7229
      ok do you have a point to make or a question to ask about a problem?
        • 22960
        ysshin79 has found a solution and is sharing. Thank you sir.
        I can't read his handwriting on the samples though. =^..^=
        • ysshin79
          • May 2017
          • 37
          Thank You Sir.
          I am Korea Republican.
          Sample handwriting is Hangul.
          The handwriting is in Korean language, and painting the sensor sensor with a black oil pen means that the symptoms will be solved.
          It is a translation of Korean language into English into Google Translator. Thank you.
          • screw
            • Feb 2021
            • 3
            I have same jam J 7229 today, on km 950 with FS-532 finisher. I see that paper hit the black plastic on exit. To solve problem on quickly i cut that plastic. I will put new plastic but it works withoutScreenshot_20210914_190118.jpg
            • wjurls
              • Feb 2017
              • 492
              Originally posted by screw
              I have same jam J 7229 today, on km 950 with FS-532 finisher. I see that paper hit the black plastic on exit. To solve problem on quickly i cut that plastic. I will put new plastic but it works without[ATTACH=CONFIG]50139[/ATTACH]
              No need to replace the plastic. They will work fine with the end trimmed off. Konica upgraded this exit guide in later later revisions.
              • FixitYo
                • Sep 2020
                • 15
                Thank You .... this tip got me right to the problem, spot on!!
