Replacing the rollers
  • Bix
    • Apr 2018
    • 1421
    Hi,
    I would like to make a comparison with you. How often do you replace the MFP rollers (pickup roller, feed roller, knowing roller etc.)?
    Every 300,000 copies are written in the manual. Do you prefer to replace or "clean" them?
  • tsbservice
    Field tech
    • 8064
    Re: Replacing the rollers
    Hi Bix. Obviously it depends heavily on the type of paper customers use..
    Cheep and with bad quality papers equal to premature rollers life(and many other parts). With bad paper here they will start misdeeding and jamming around 200k. Cleaning helps a bit.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4785
      If you are talking about the the "4" series and newer your should replace rollers anytime over 200k when you get a call for misfeeding/jamming and service history shows more than 5 jams from the adf or paper drawers in last 2-4 weeks. 5 is just a number I use but you still have to "interview" the customer for more information, what type of paper, etc, etc. Of course if I see 5 jams 1 min apart and that's all I see in history I can assume it was one thing customer was doing wrong, i.e. trying to feed thick paper, etc and not an issue with rollers.
      Good point by BC about aftermarket rollers. I use the China aftermarket rollers and why I replace them automatically at 200k (if they make it that far). If you get 200k out of them you are way ahead of the game, just replace. I may go back to OEM on the 4 series. I was going through so many rollers with the C253 series that I switched to aftermarket. Now that most of what I service are the 4 series probably will only have to change rollers once for life of machine with OEM rollers.
        • 15011
        I just use the counter as a guideline. I replace the rollers when they look like they need to be replaced. I have replaced them at 150k and at 320k.
          • 23010
          Aftermarket rollers will do 150K, OEM: between 400K & 580K in the right circumstances.
          In the end though I don't let the count be the primary factor. If the sep roller is smooth, tapered or flattened the machine will get new tires regardless of the count. =^..^=
          • roho
            • Mar 2009
            • 844
            So many customers, especially large corporate accounts, now seem to have deals or contracts for some pretty pi$$ poor quality paper. The cost of simple rollers is cheaper then the parking at most of these accounts so if the sep roller looks worn I replace all of them on mid size models.
            • magicaljake
              • Jun 2018
              • 22
              I usually replace the rollers when the separator roller no longer has visual texture.
              • Hansoon
                • Sep 2007
                • 3400
                Exactly, but never more than 120K. At the same time oneways are being cleaned and the shafts scuffed up. Have many remote customers and the costs of travel are far higher than a set of rollers not to mention the good Karma...... lol
                Did I say I HATE paper jams?
                Hans
                • copier tech
                  • 8220
                  The sign of a bad engineer is replacing rollers everytime he gets sent to a machine jamming, regardless of their life or even the jam code!
                  I usually replace the rollers at each PM or each time I replace a drum.
                  Also if the customer only has a 2 tray config tray 1 usually does most of the work so i'd keep an eye on their life.
                  • 3ktlc
                    • Feb 2018
                    • 180
                    I try cleaning them first. Then run test copies and have the customer run multiples.
                    Unless they are close to life end. Then I replace.
