Konica C284e/C364e firmware File
  • troll0201
    • Jul 2018
    • 6
    Hi all
    Can anyone send me the firmware and movie data file for the C284e/C364e?
    Thanks in advance!
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: Konica C284e/C364e firmware File
    check your PMs
    thanks for being a contributor!
    • cccc213
      • May 2019
      • 3
      Hi all,
      I also need the firmware file.
      Can anyone send me the firmware and movie data file for the C284e?
      Thank you. This is a great forum for finding solutions. Thank you very much to all users which are helping others.
      • tsbservice
        Field tech
        • 8052
        Originally posted by cccc213
        Hi all,
        Are you technician?
        What's wrong with the machine?
        Becoming contributor may also help, see above.
        • cccc213
          • May 2019
          • 3
          No, I'm a enduser and contributor to this forum. Error-Code C-FA14 => Changed HDD, then C-D010 error. Logical format not possible.
          I will try the newest firmware and copy the movie data for my C284e. Please can anyone send me a pm with the firmware and movie data file for the C284e? Thank you
          • khaledads
            • May 2019
            • 3
            [QUOTE=troll0201;694896]
            Hello
            Thanks in advance!
            • Ari007
              • Apr 2019
              • 49
              I can give you the firmware but need to confirm some details first. Please tell the exact problem first. I don't want your machine to get screwed.
              **I own a Bizhub C224e & I'm already familiar with the problems of these series machines.
              Please post the serial number also.
              • khaledads
                • May 2019
                • 3
                Are you technician?
                Hello
                I'm a technician I import machines from Germany and I received one machine have these errors
                Copy/scan no available
                Zero meter counter
                Regards
                • Synthohol
                  • 5892
                  Originally posted by khaledads
                  Hello
                  Zero meter counter
                  Regards
                  likely a scanner error.
                  shut off with main power behind door, hold down panel reset and power back on. close door right away while still holding panel reset until you see a black dot top right of screen. release button.
                  when you see trouble reset on screen touch it, should say OK.
                  turn it off, count to 10 and turn back on.
                  if it was a serious error tell us the code that pops up.
                  if error was just silly, you should be able to copy.
                  as far as the zero meter, someone botched a procedure.
                  anyway, let us know.
                  • khaledads
                    • May 2019
                    • 3
                    Are you technician?
                    Hello
                    Zero meter counter
                    Regar
                    • Synthohol
                      • 5892
                      i just said all this...
                      • mhmds102466
                        • Jul 2019
                        • 74
                        Originally posted by troll0201
                        Hi all
                        Thanks in advance!
                        How are you? I have a Bizhub c284eShow on screen
                        serial number must be entered contact your service representaive
                        • Ari007
                          • Apr 2019
                          • 49
                          Press Reset and turn the power switch on..
                          Login to service menu...
                          Input serial numbers..
                          And exit ... Done... Calibrate the machine if required..
                          • mhmds102466
                            • Jul 2019
                            • 74
                            After entering the Login to service menu where I find the Input serial numbers list.
                            • Ari007
                              • Apr 2019
                              • 49
                              Service Menu> System 1> Serial Number
