Konica C284e/C364e firmware File
  • mhmds102466
    • Jul 2019
    • 74
    #16
    Re: Konica C284e/C364e firmware File
    Originally posted by Ari007
    Press Reset and turn the power switch on..
    Login to service menu...
    Input serial numbers..
    And exit ... Done... Calibrate the machine if required..
    I am sorry for the inconvenience, but I am very upset by the machine I did not say it with the letter and I got it wrong again Code number C-D010 and before it the god worked but all the colors are not visible and the appearance of lines when shooting in the paper and all sizes paper is not equal I want the Calibrate the machine if required
    • mhmds102466
      • Jul 2019
      • 74
      #17
      Service Menu> System 1> Serial Number
      After entering the serial number, the message no animation guide available
      • copier tech
        • 8200
        #18
        You need to reinstall the animation firmware.
        • Ari007
          • Apr 2019
          • 49
          #19
          Go to Service Menu>System 2>HDD> Click Not Installed..
          Animation Guide error will not disturb you again ... (This is a temporary solution)
          Install the animation Guide file once you find the movie data file.. (turn hdd on first from System 2> HDD > Installed)
          If you turn off HDD, multi page pdf scans having pages more than 10 will not transmit to your PC. Machine might hang. Normal printing operation will work fine.
          • mhmds102466
            • Jul 2019
            • 74
            #20
            Where do I find animation firmware
            • mhmds102466
              • Jul 2019
              • 74
              #21
              To date code number C-D010 has not gone
              Please I want to solve all the problems because the machine does not work and I am very sad WhatsApp Image 2019-07-29 at 9.32.20 AM.jpg
              • Hansoon
                • Sep 2007
                • 3391
                #22
                End user?
                Hans
                • mhmds102466
                  • Jul 2019
                  • 74
                  #23
                  Originally posted by Hansoon
                  End user?
                  Hans
                  Yes I'm the end user it's my machine in the office
                  • srvctec
                    Former KM Senior Tech
                    • Oct 2009
                    • 827
                    #24
                    Then call a tech to fix your machine!!!
                    As much time and effort as you've spent posting all over this forum in multiple places about the exact same thing, you could have called a tech and had it working already.
                    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                    • mhmds102466
                      • Jul 2019
                      • 74
                      #25
                      I called the engineer of Monletta before he was a fraudster he came to the office and shut down all color photocopiers with a password and a password
                      Service Malnual
                      I do not trust any engineer
                      I love I work with my hand
                      Thank you
                      Thanks for all the forum
                        Service Malnual
                        Thank you
                        well then you come here..... try to pick our brains (because you have no FUCKING idea on what you're doing)... and THEN say you don't trust Service Engineers?
                        Whisky Tango Foxtrot?
                        WE HERE ARE SERVICE ENGINEERS!!!!!
                        maybe the 'other' engineer figured out what a SHIT for BRAINS you are, and knew you were a lost cause.
                        YES it IS customary for a Tech/Engineer to enable passwords.. to keep STUPID users from FUCKING THINGS UP!
                        LOOK thru the threads, at all the end users that think doing an "ALL CLEAR" on the machine THINKING that will solve the problem -=OR=- the ones that FORMAT their HHD without: 1) the service manual 2) have performed a BACKUP of all DATA 3) do not have the proper files to re-install 4) HAVING a FUCKING CLUE of what they are doing
                        Most Techs here have gone thru HOURS and HOURS of training on JUST ONE MODEL...
                        Having been in the industry for 30+ years, I know with my THOUSANDS of Certs on MOST BRANDS I have spent more time than a MBA would for a degree.
                        BUT morons like YOU think you can be my EQUAL... it will never happen (BTW .. Yes I do have OTHER degrees also)
                        • mhmds102466
                          • Jul 2019
                          • 74
                          #27
                          [QUOTE = Phil B.؛ 790281] حسنًا ، أتيت إلى هنا ..... حاول اختيار أدمغتنا (نظرًا لعدم وجود فكرة عن ما تفعله) ... ثم تقول إنك لا تثق في الخدمة المهندسين؟
                          ويسكي تانجو فوكستروت؟
                          نحن هنا مهندسون خدمة!
                          ربما اكتشف المهندس "الآخر" ما هو القرف بالنسبة لك ، وأنت تعلم أنك سبب ضائع.
                          نعم ، من المعتاد بالنسبة لـ Tech / Engineer أن يقوم بتمكين كلمات المرور .. للحفاظ على مستخدمي STUPID من الأشياء المزعجة!
                          انظر من خلال الخيوط ، على كل المستخدمين النهائيين الذين يعتقدون القيام بـ "ALL CLEAR" على الجهاز الذي سيؤدي إلى حل المشكلة - = أو = - تلك التي تشكل HHD دون استخدام:
                          لقد مرت معظم التقنيات هنا من خلال HOURS و HOURS من التدريب على JUST ONE MODEL ...
                          بعد أن أمضيت أكثر من 30 عامًا في هذا المجال ، فأنا أعلم مع آلاف من Certs في أكثر الماركات التي قضيتها في الجامعة .
                          لكن كآبة مثلك تعتقد أنك يمكن أن تكون EQUAL ... لن يحدث ذلك أبداً (راجع للشغل .. نعم لديّ درجات أخرى أيضًا) [/ QUOTE]
                          I'm sorry
                          I do not mean insulting you
                          I am evening what the engineer did
                          I had a password from 1 to 8
                          The engineer came without my knowledge and changed the password. I came to see another engineer who said I do not know the password
                          I am sorry again
                          We are all brothers and I do not like to be insulted or wrong in anyone
                          • Ari007
                            • Apr 2019
                            • 49
                            #28
                            Don't get angry on him..
                            He's not trying to compare him with a tech.
                            I faced similar issues like him. There are lot of techs in many dealerships without proper troubleshooting knowledge and they just recommends to swap things out. I described the problem in detail (Link: http://www.copytechnet.com/forums/ko...tml?highlight= ) ...
                            There are lot of ways they'll (shit techs) try to extract money from the customer. And there are good techs who'll suggest which solution will be best for the customer..
                            • Ari007
                              • Apr 2019
                              • 49
                              #29
                              Please I want to solve all the problems because the machine does not work and I am very sad [ATTACH=CONFIG]43204[/ATTACH]
                              go ahead..
                              • mhmds102466
                                • Jul 2019
                                • 74
                                #30
                                .. [/ QUOTE]
                                The code problem c-d010 has been resolved
                                And the rest of the problem lines
                                When copying
                                And the rest of the Animation Guide Data files
