Konica C284e/C364e firmware File
  • mhmds102466
    • Jul 2019
    • 74
    #31
    An image attachment describes the problem when copying Konica C284e
    • Synthohol
      Certified Konica Expert
      • 5892
      #32
      Re: Konica C284e/C364e firmware File
      lines of shame.
      follow the setup instructions s if you just unboxed it.
      • mhmds102466
        • Jul 2019
        • 74
        #33
        [QUOTE = Ari007؛ 755572] يمكنني أن أعطيك البرنامج الثابت ولكن يجب تأكيد بعض التفاصيل أولاً. من فضلك قل المشكلة بالضبط أولا. أنا لا أريد جهازك للحصول على ثمل.
        ** أنا أملك Bizhub C224e وأنا بالفعل على دراية بمشاكل هذه الآلات.
        الرجاء نشر الرقم التسلسلي أيضًا. [/ QUOTE]
        Problems of latitude red and blue have not been resolved so far I want the firmware file to reset from the first and new can solve the problem I am trying more than 3 months did not find a solution.
        [COLOR=rgba(0, 0, 0, 0.54)]
        [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]
        [/COLOR]
        • Synthohol
          • 5892
          #34
          RTFM!!!
          • tsbservice
            Field tech
            • 8052
            #35
            Originally posted by Synthohol
            RTFM!!!
            Hey Synt, bsm2 may sneak in here to envy your big font and invent even bigger
              good one!
              • kimirai
                #37
                Hi all
                I appreciate if anyone could send me the firmware and movie data file for BHC 224e/284e/364e?
                The machine current firmware version Version 3, thus the Airprint fuction is not available.
                Is the method of updating firmware same as BHC 220/280/360? I used to update the firmware without updating the animation guide.
                Thank you very much.
                Kimi.
                • Bix
                  • Apr 2018
                  • 1421
                  #38
                  Originally posted by kimirai
                  Hi all
                  Kimi.
                  Hi, make a donation to the forum.
                  Firmware and animated guide are two separate files. For the firmware update use the manual, remember that in the 4 series you must use the USB service port.
                  • fuck1ng
                    • Dec 2019
                    • 16
                    #39
                    Hi guys-
                    I need the firmware for c364e.
                    The problem is that was block for print.. this cant print. So i need reinstall the firmware to unblock that.
                    The firmware that the machine have is version 5.
                    Plz guys help me.
                    • Synthohol
                      • 5892
                      #40
                      Financial contributors get what they want.
                      Also what an original avatar name, did you come up with that yourself or did a 12yo youtuber help?
                      • fuck1ng
                        • Dec 2019
                        • 16
                        #41
                        Whats the problem with my avatar name? make u at problem? i have 33 yo dude... and i dont know whats the problem with that.. but anyway.
                        want pay to page or for u?
                        • Synthohol
                          • 5892
                          #42
                          not for me, for CTN.
                          https://www.copytechnet.com/forums/v....php?do=donate
                          • copier tech
                            • 8200
                            #43
                            Originally posted by fuck1ng
                            Hi guys-
                            Plz guys help me.
                            What is your exact issue, you can't print? do you can any message on the screen? have you tried a new driver?
                            Unlikely firmware will fix this issue sounds like you have user authentication turned on?
                            • tulintron
                              • Jul 2014
                              • 668
                              #44
                              Hi guys-
                              Plz guys help me.
                              initialize / clear all data within service mode.enable HDD, logical format, configure TCP / IP.
                              Likely user restriction enabled.
                              • fuck1ng
                                • Dec 2019
                                • 16
                                #45
                                i was try with that. but ive a little problem.. i cant log on service mode... this machine was change the password and i was try to bypass and nothing work.
                                The problem with the print this send to the machine, this turn on the light and dont print.. when i check on list job say loggin error.
                                and this problem fix with reinstalling firmware
