Konica C284e/C364e firmware File
    Re: Konica C284e/C364e firmware File
    Originally posted by fuck1ng
    Whats the problem with my avatar name? make u at problem? i have 33 yo dude... and i dont know whats the problem with that.. but anyway.
    want pay to page or for u?
    fuck1ng is pretty poor name...
    UNLESS you are talking about your English.
    33? still a kid compared to most of us here.
    Synth was talking about being a CONTRIBUTOR to CTN.... to obtain the files you request.
    ***HINT*** drop the attitude you will not get anywhere with it.
    • fuck1ng
      • Dec 2019
      • 16
      #47
      well anyway.. sorry for all..
      ill contribute the monday. dont worry and thanks for your help.
      • Copier repairman
        • Aug 2019
        • 86
        #48
        [QUOTE = cccc213; 755173] 아니요, 저는이 포럼의 최종 사용자이자 기고자입니다. 오류 코드 C-FA14 => HDD 변경 후 C-D010 오류. 논리 형식이 불가능합니다.
        최신 펌웨어를 사용 해보고 C284e의 동영상 데이터를 복사합니다. 누구든지 C284e의 펌웨어 및 영화 데이터 파일과 함께 오후를 보낼 수 있습니까? 감사합니다 [/ QUOTE]
        Hi?
        Please follow the instructions below.
        1. Enter service mode
        2. Select System 1
        3. Select Initialization-> Clear All Data-> Start->
        Power off / on message is displayed when off / on.
        4. Enter service mode
        5. Select System2-> Select HDD-> Select No Mount-> OK->
        6. Enter service mode
        7. Select main unit-> SSD format-> Logical format-> Start->
        8. Enter service mode
        9. Select System 2-> HDD Selection-> Mounting-> OK->
        10 Enter service mode
        11. Select Main Unit-> HDD Format-> Logical Format-> Start->
        12. Enter service mode
        13. Select System 2-> Select Next Page-> Select Install Data->
        Insert USB with video data on the right side of the OP panel->
        Select video-> register-> blue LED on start button->
        Close the service mode window.
        • SL_Larry
          • Dec 2019
          • 8
          #49
          Dear All,
          I hv Dl the firmwares for updating C364e, but I put my USB drive to back service port and Power ON the machine,
          which did't load to the update page, it just reboot the machine only. I hv try two firmwares:
          1. A5C10Y0-F000-G20-A9 and
          2. A5C10Y0-F000-G20-K9
          Could somebody tell me, is there anythine worng here? thanks a lot.
          Larry
          • Synthohol
            Certified Konica Expert
            • 5892
            #50
            use a 4 gig or smaller flash drive formatted fat32
            on the 4 series you put all the folder contents in the root.
            get g20-m1 firmware.
            • SL_Larry
              • Dec 2019
              • 8
              #51
              Thanks a lot, Synthohol
              I have updated the firmware to G20-M1, by a 4GB USB drive.
              Another question is: for this C364e is there a function with wifi mode? or just LAN access?
              becoz if can't find the"
              Network I/F Configuration
              " to config the machine.
              • Synthohol
                • 5892
                #52
                wifi is a kit sold separately
                if the copier is on the wired network and the wireless is on the same subnet as the wired network then you can print and scan wireless for free.
                • SL_Larry
                  • Dec 2019
                  • 8
                  #53
                  how could I know wether the machine have wifi kit or not?
                  thanks
                  • Bix
                    • Apr 2018
                    • 1421
                    #54
                    Hi, the kit to assemble is UK-208. More information you may need in Service Mode> 2nd Network Setting
                    If you don't have it, it's not strictly necessary. If the network is the same, you can safely use your router wireless. You could also use a wireless repeater with a LAN port that costs around $ 30 on Amazon. The wireless module costs a lot, only in rare cases it has been useful. Especially if you need to configure two networks for the same printer.
                    • SL_Larry
                      • Dec 2019
                      • 8
                      #55
                      Thank you, I enter the service mode and activated the "LAN and wireless" mode.
                      But there is a "internal error", system reboot several times, then shown "C- D262"
                      what is that means?? how to solve?
                      • Synthohol
                        • 5892
                        #56
                        it means you dont have one installed.
                        deactivate it and do some more research on the topography of the environment.
                        ^^^^^^best advice^^^^^^
                        • SL_Larry
                          • Dec 2019
                          • 8
                          #57
                          Thank you both of you!!
                          I can print through wifi now.
                          It seems that I can't use smart-phone or pad to do so that I want it most, because of no module inside the machine..........
                          • Synthohol
                            • 5892
                            #58
                            install the konicaminolta mobile print app and find it via IP if you can print wirelessly.
                            • SL_Larry
                              • Dec 2019
                              • 8
                              #59
                              I hv tried it already,
                              but it is not worked in this C364e(can't be searched by IP or AUTO), but my another printer C458e did.
                              So I guess, my phone can't print through the APP by using my C364e without wireless module..
                              • Bix
                                • Apr 2018
                                • 1421
                                #60
                                Are you sure the MFP's network configuration is ok? Gateway?A few minutes ago I configured a C364e and C284e on Konica Minolta Mobile Print without problems. I don't know if the firmware needs to be updated, I have version 7 in it
