Konia Minolta C452/552/652 NVRAM Reset Tool Firmware
  • mindhunter
    • May 2008
    • 146
    hi guys .
    Does anybody know whats the name of firmware for reset NVRAM on this series ?>
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: Konia Minolta C452/552/652 NVRAM Reset Tool Firmware
    1. Release version and download file name
    The newly released program version and download file name is as follows.
    [Release version]
    <C652/C652DS/C552/C552DS/C452/C360/C280/C220/652/602/552/502/423/363/283/223 Jig firmware>
    bizhub C652/C552
    Jig firmware
    GQ7-D1
    A0P00Y0-F000-GQ7-D1.exe
    bizhub C652DS/C552DS
    Jig firmware
    GQ7-D1
    A1DM0Y0-F000-GQ7-D1.exe
    bizhub C360/C280/220
    Jig firmware
    GQ7-D1
    A0ED0Y0-F000-GQ7-D1.exe
    bizhub 652/602/552/502
    Jig firmware
    GPD-F9
    A2WU0Y0-F000-GPD-F9.exe
    bizhub 423/363/283/223
    Jig firmware
    GQ7-D1
    A1UD0Y0-F000-GQ7-D1.exe
    [Download file name]
    • yasinzaeem
      • Jan 2017
      • 8
      hello dear all,
      can someone share with me "jig firmware gpd-f9 a2wu0y0-f000-gpd-f9.exe" nvram initialize tool for bizhub652.
      thanks
      • Synthohol
        • 5847
        if you have one of these below your name you get a reply so much faster.
        just saying...
        https://www.copytechnet.com/forums/v....php?do=donate
        • johnysig
          • Dec 2019
          • 2
          I need the Firmware for C452 Please. All i get is the time glass at boot up and they fix is suggested to be the firmware.
          johnysig@gmail.com
          • Synthohol
            • 5847
            just saying...
            • johnysig
              • Dec 2019
              • 2
              can this be sent to me please. The Firmware for C452. johnysig@gmail.com
              • Synthohol
                • 5847
                link sent via PM.
                thanks for contributing!!
                also here are the instructions.
                • mtavassoli
                  • Jan 2020
                  • 4
                  can this be sent to me please. The Firmware for C652 . thanks mtavassoli63@gmail.com
                  • tsbservice
                    Field tech
                    • 8020
                    just saying...
                    See above, use the link.
                    • copier tech
                      • 8174
                      Why do you need it, do you have a specific fault/issue?
                      • mtavassoli
                        • Jan 2020
                        • 4
                        Hi First of All i Can't install this printer via Usb with any Driver and the only Way to Use it is from lan network
                        Second, sometimes printer couldn't start and i have to turn off and turn on unit, and i think this Problem because of lack of firmware
                        • Albonline
                          • Sep 2008
                          • 1151
                          do you know if it has the usb interface option installed? slide in card on mfp.
                          • mtavassoli
                            • Jan 2020
                            • 4
                            of course yes , sometimes via usb printer has error on print and it print blank page with error on top and then i install other driver like 3.7 & .... after i change driver the first page is ok but other pages is blank with error so i have to change detection to lan network and in this condition it's good but sometime i have to turn off and turn on to work properly
                            • Albonline
                              • Sep 2008
                              • 1151
                              what your describing usually happens when a bad print job is received. or when the nic is excessively pinged. try running a port monitor on your setup.
